OBD2B ecu work on a OBD2A?
Old May 15, 2006 | 07:13 PM
t_c_l_6's Avatar
Default OBD2B ecu work on a OBD2A?
I need to know if an Ecu from a 99 GSR (OBD2b) will work on a 96 GSR(OBD2A). Thanks
Old May 15, 2006 | 07:21 PM
98IntegraLSNonVtec's Avatar
Default Re: OBD2B ecu work on a OBD2A? (t_c_l_6)
I doubt it..because the OBD2B ECU has an immobilizer in it...should wait for more info. though..this is just my thought
Old May 15, 2006 | 08:00 PM
t_c_l_6's Avatar
Default Re: OBD2B ecu work on a OBD2A? (98IntegraLSNonVtec)
bump
Old May 16, 2006 | 04:22 PM
t_c_l_6's Avatar
bump
Old May 16, 2006 | 05:23 PM
PY TYPE R 483's Avatar
you would also need a wire harness to change the ECU
Old May 16, 2006 | 05:24 PM
comteg396's Avatar
will work fine. you need OBD2B-OBD2A harness and remove immobiler
Mass13
Honda CR-V & Element
12
Mar 24, 2014 04:39 AM
patdow1
Apr 21, 2009 04:35 AM
Scubster
Dec 21, 2004 10:21 PM
Trust No One
Feb 3, 2003 04:12 PM
