help with swap!!
i just finished a auto to manual conversion and gsr engine swap into my ls and it wont start. it cranks and gets fuel but wont fire. my neighbor told me that the automatic and manual ignition switches are different but the only difference i can see is this plug ( see picture)
[img]
[/img]
can anyone tell me what that plug is for. any input is appreciated.
[img]
[/img]can anyone tell me what that plug is for. any input is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLova »</TD></TR><TR><TD CLASS="quote">Im pretty sure your gonna need a manual starter.Someone correct me if im wrong.</TD></TR></TABLE>
already have a manual starter. it was a complete swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grannyshifter »</TD></TR><TR><TD CLASS="quote">I also just finished doing the same auto to manual conversion in my 94 ls but with a ITR motor. mine started rite up, didnt need to change the ignition switches.</TD></TR></TABLE>
really? then i guess that plug isnt the problem. but anyways does anyone know what its for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECKOTYPER »</TD></TR><TR><TD CLASS="quote">check the motor grounds</TD></TR></TABLE>
im pretty sure all motor grounds are hooked up. but ill check again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">did you rewire the automatic shift lever to trick the car into thinking its in park?</TD></TR></TABLE>
no, i swapped out the complete harness, under dash and all. i shouldnt have to wire anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">why did u swap the harness? everything is the same u just cut off the auto plugs from the harness thats all.</TD></TR></TABLE>
i swapped it out because its not the same, the ecu plugs are different, there was no wiring for the vtec solenoid or manual tranny, and there was no wiring for the clutch pedal. and i suck at doing wiring myself.
ericjackson
Jun 21, 2005 01:52 PM
