VTEC NOT WORKING
Old May 16, 2006 | 03:22 PM
95GSRDC2's Avatar
Default VTEC NOT WORKING
hey my vtec doesnt seem to be working all the way, any suggestions?
Old May 16, 2006 | 03:25 PM
Nighthawk R18's Avatar
Default Re: VTEC NOT WORKING (jonny22785)
please explain..
Old May 16, 2006 | 03:28 PM
95GSRDC2's Avatar
Default Re: VTEC NOT WORKING (x Da Clutch 5 x)
ok well you know how a gsr vtec works right?, it kicks in a little bit at first then it screams well i dont think it screams any more i cant really tell because i live in new england and its been raining for like 2 weaks
Old May 16, 2006 | 03:34 PM
cm zak's Avatar
Uhm, your not really good at this car thing are you?
check your solenoids, or maybe you have a bad injector..
is your CEL light on?
Old May 16, 2006 | 03:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">Uhm, your not really good at this car thing are you?</TD></TR></TABLE>
...hahah
jonny22785, btw try searching. im sure this has been covered already
Old May 16, 2006 | 06:53 PM
Damon Reeves's Avatar
Check your oil pressure..
Old May 16, 2006 | 06:57 PM
MaGoodc2's Avatar
Default Re: VTEC NOT WORKING (My DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Check your oil pressure..</TD></TR></TABLE>
are you letting your car warm up to normal temp before smashing on it?
Old May 16, 2006 | 07:53 PM
XpLiCiD_GsR's Avatar
check your oil.....if you are running low, it will not alow your vtec to work properly
Old May 16, 2006 | 08:02 PM
ecks_fourttwo's Avatar
any cel's???
Old May 17, 2006 | 04:58 AM
95GSRDC2's Avatar
Default Re: (ecks_fourttwo)
no check engine light.
Old May 17, 2006 | 10:08 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (jonny22785)
check your oil level...also check your VTEC pressure switch. how? disconnect the connector from the pressure switch (green plug thats connected to the solenoid attached at the end of your camshaft)
S2KILLA's Avatar
Default Re: (SupersonicBlueGSR)
ohh and reset ur ecu, let her warm up and try it out
Old May 17, 2006 | 10:09 AM
7mile's Avatar
Default Re: VTEC NOT WORKING (XpLiCiD_GsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XpLiCiD_GsR &raquo;</TD></TR><TR><TD CLASS="quote">check your oil.....if you are running low, it will not alow your vtec to work properly </TD></TR></TABLE>
Old May 17, 2006 | 04:28 PM
thanks
Old May 17, 2006 | 04:47 PM
95GSRDC2's Avatar
Default Re: (XpLiCiD_GsR)
how would i reset the ecu? just disconnect the battery?
Old May 17, 2006 | 04:54 PM
1337whp's Avatar
also vtec solenoid screen could be clogged - somehow - maybe cus its been rainin with vtak enguaged?
Old May 17, 2006 | 07:26 PM
yea disconnect the battery for like a minute....like 1337 said as well, check vtec selenoid screen
Old May 17, 2006 | 08:30 PM
LSracing94's Avatar
its probably workin fine..what year is it
Old May 18, 2006 | 05:04 AM
95GSRDC2's Avatar
Default Re: (LSracing94)
94 it did work when i bought it a few months ago but now it doesnt seem to be working right.
Old May 18, 2006 | 06:30 AM
LSracing94's Avatar
ok well, does the car actually fall out of vtec?? or does it not feel as strong or something.
Old May 18, 2006 | 06:48 AM
Micha's Avatar
FAILWGN
or did someone swap a LS motor into your car without you knowing about it?
Old May 18, 2006 | 06:57 AM
Sijray21's Avatar
if you're not blowing a CEL, it's likely you have low oil levels - causing a loss in oil pressure - to which vtec will not engage. If the engine is not up to normal operating temperature you will be vtec-less.
good luck
Old May 18, 2006 | 04:27 PM
95GSRDC2's Avatar
Default Re: (Sijray21)
i have plenty of oil
Old May 18, 2006 | 04:32 PM
pennies_hatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonny22785 &raquo;</TD></TR><TR><TD CLASS="quote">ok well you know how a gsr vtec works right?, it kicks in a little bit at first then it screams well i dont think it screams any more i cant really tell because i live in new england and its been raining for like 2 weaks
its probably your IAB. vtec kicks in first and then the IAB. its your IAB that screams, not vtec. so check to see if the plug is bad or something and it wont pull a CEL as well. so if you do feel vtec @ the early rpms, then vtec works
