Ignition problem?
Old May 15, 2006 | 01:54 PM
kDA's Avatar
kDA
Default Ignition problem?
I have a 91 Teg RS, I up keep it as best I can and have it tuned up on time when its supposed to, there are no engine mods to it, so its butt *** stock, only cosmicitic mods, today after class I tried to start my car up and it would wind up and then bog off, I checked the spark plug wires and distrubutor and they were all plugged in, I then put it into first gear and then started the car, it worked, this has never happened before, and I'm wondering what the problem might be, My first guess is the main fuel relay needs to be replaced, but I havent checked because I need to go to work in 10 min, just wanted a few other opinions on what it might be.
Old May 15, 2006 | 04:49 PM
slpr_civic93's Avatar
Default Re: Ignition problem? (kDA)
if your car is v tec then check the wires. my hatch had the same problem. it was hard to start and i thot it was the ignition or the spark plugs. but then i realize that my v tec wasnt kickin in and then i fix it. after i fixed it, it worked fine. i not really sure if it would work on your motor becus mine was a b16. jus a thot.
Old May 15, 2006 | 05:42 PM
Danziver's Avatar
Im having problems with my main relay now. They say it helps to unbolt it and let it hang b/c it stays cooler that way, i also cut some holes into the brown housing to help it stay cool. This is untill i can get a new one.
Old May 15, 2006 | 07:23 PM
Danziver's Avatar
Default Re: Ignition problem? (Danziver)
They are 25$ new at auto zone. I could pick one up used at the junk yard but i dont know if thats a good idea. Hopefully this fixes the problem.
Old May 16, 2006 | 01:46 PM
Danziver's Avatar
Relay didnt fix the problem, gonna try my ignition switch next.
Car gives me a hard time starting when its cold. The engine will spin but it wont crank, i hear the fuel pump priming and the realy clicking.
Any imput would be appreciated.
Thanks
Old May 16, 2006 | 03:49 PM
Danziver's Avatar
ok. My car just died on me twice leaving work just now, barley made it home. Im gonna try the ignition switch now.
Old May 16, 2006 | 06:07 PM
Danziver's Avatar
I cleaned the contacts on my ignition switch and it made starting a little better, but its still rough.
Old May 17, 2006 | 04:21 AM
Danziver's Avatar
Learned a new trick, if yoiu have a bad ignition switch try starting the car and tapping on the ignition switch with a wrench or something. This helps a bit.
Old May 17, 2006 | 07:41 AM
Danziver's Avatar
New ignition switch didnt fix the problem. Help!!!
Old May 18, 2006 | 01:05 PM
Danziver's Avatar
Turns out it was the crappy discount auto parts distributor the i bought 1 month ago.
GuitarPunk015
Jun 25, 2009 03:24 PM
94integraturbo
Jul 14, 2007 11:30 AM
Dspad_91Civic
Aug 14, 2005 04:45 PM
eric416
Jul 15, 2005 11:39 AM
grown_up_wagon
Aug 2, 2004 05:14 AM
