Alignment
Old May 17, 2006 | 04:40 PM
Fliplm0de's Avatar
Default Alignment
Sorry for the noob question, but i just drove my car since its been garaged for a while being fixed.. i noticed while i was driving i was going striaght but my wheels was kinda tilted to the right?? (bad example but: ie this would be striaght " | " i was like " / ".
would this be an alignment problem? i was wondering if having flat tires, different size tires could be the reason? or could it be the control arm thanks HELP PLEASE!
Old May 17, 2006 | 05:05 PM
95IntegraGSRAZ's Avatar
Default Re: Alignment (Fliplm0de)
Can be fix by adjusting the tie rods... assuming everything else is mechanically sound. Bring it to an alignment shop and they can fix it in mins... they just need to put it on the rack and adjust.
Old May 17, 2006 | 05:12 PM
Fliplm0de's Avatar
Default Re: Alignment (civicvteckid)
thanks would this cost a lot to fix?
Old May 17, 2006 | 05:51 PM
if its just misaligned... it would only cost the price of an alignment.
Old May 17, 2006 | 05:53 PM
DC2 Mang's Avatar
if you want to try alligning it your self check out the DIY link on http://www.c-speedracing.com
Old May 17, 2006 | 06:55 PM
The_Ricky_Is's Avatar
Default Re: Alignment (JDMdc2lsVtec)
it could something like a bad alignment, or it could be something as simple as uneven air psi. check the psi of the tires before jumping to any big conclusions (sp?). if anything worst, probably just out of alignment.
Old May 17, 2006 | 08:22 PM
Hoagieryder's Avatar
Default Re: Alignment (The_Ricky_Is)
alignments vary in prices whether it is 4 way or not, I got all 4 wheels for about 50 bucks at a local place.
Old May 17, 2006 | 08:27 PM
02 accord's Avatar
The string idea is stupid. If your front end is different width than the back end, your alignment will be off.
mickey513
Suspension & Brakes
Sep 13, 2013 06:05 PM
sd619jef9
17
Nov 25, 2011 01:41 AM
whteteg8901
Suspension & Brakes
Apr 6, 2008 09:35 PM
civicsracer
Dec 5, 2006 05:30 PM
efboy
Suspension & Brakes
Apr 14, 2005 06:40 PM
