HELP!!! VTEC PROBLEM
Old Apr 1, 2007 | 08:47 AM
hondarny's Avatar
Default HELP!!! VTEC PROBLEM
i just built and ls/v setup Ls block, ls crank, ls rods, CTR and si head... not tuned yet
every time im driving it, from 0 to 5000 the car rides fine, but after that when the vtec is bout to pop it acts like its in slowmotion, takes a while to pass 6000 if it does!!!
advices please
Old Apr 1, 2007 | 09:14 AM
fliptout's Avatar
Default Re: HELP!!! VTEC PROBLEM (hondarny)
I'm running the exact same setup, Si head Eagle rods and crank, it sounds like it may be your timing or your distributor. check all your timing marks. But if you are hitting 5000 rpm then it is most likely your distributor crapping out at higher RPM's. You shoul test your coil and ignitor.
Old Apr 1, 2007 | 10:57 AM
blackKready's Avatar
Default Re: HELP!!! VTEC PROBLEM (fliptout)
you should not be beating that car with that high of compression without tuning perhaps? lol. is prolly a good idea. you should be running at least an ITR base. if you hear pinging dude , let off and take it easy , youl hurt it. its brand new. why would you risk hurting your new engine? impatience can be very exspensive , lol.
Old Apr 1, 2007 | 11:22 AM
doood's Avatar
been there done that
you shouldnt even be driving it. you could be doing some serious damage right now.
Old Apr 1, 2007 | 01:27 PM
hondarny's Avatar
anyone else? HELP!!!!!!!!!
Old Apr 1, 2007 | 01:29 PM
doood's Avatar
seriously, are you trying to blow it up?
Old Apr 1, 2007 | 02:18 PM
hondarny's Avatar
Default Re: HELP!!! VTEC PROBLEM (doood)
tryin to figure out wut the problem is b4 i tune it
bebe101
Nov 21, 2008 05:32 PM
Black EH6
Mar 3, 2007 06:02 AM
imskatencrzy
Sep 30, 2006 02:56 PM
KillaB18
Oct 16, 2005 06:54 PM
MysteryWagon
May 2, 2003 07:30 AM
