spring ratio off??
hey guys, so i lowered my car somemore this past week, and i have been noticing that the stance of the car is weird....it seems as if the car is front heavy, due to fact that the front is much much lower then the rear. im either thinkin that the springs are switched and that the front ones have to be moved to the back, and the rear moved to the front...or is the spring ratio off...and should i just buy a whole new set up??
please hELP!!!
please hELP!!!
it shouldn't b much lower... i noticed while looking thru the spring options that they just make the front a lil lower than the back, and ppl on the boards said it was probably just for looks. but it really shouldnt b more than half an inch lower. if it is then maybe u got the springs mixed up, cuz the back ones aren't meant to hold up an engine.
yeah, cause im tuckin major in the front....but i barely tuck in the back...i think i might have the springs switched around...imaa have to check today...is there any way to check k psychically? front spring longer/bigger then rear?
thanks for the quick response
Cru Jones
Apr 10, 2003 06:14 PM
