Check Engine Code: 22 VTEC pressure valve
Old Mar 31, 2007 | 11:24 AM
numotive's Avatar
Default Check Engine Code: 22 VTEC pressure valve
Was getting on a freeway on-ramp earlier today, decided to pop open some v-tec and as i reved through around 7k the check engine light came on. I checked the code when I got home and it was #22, which i just found out is "VTEC pressure valve". My engine has been burning alot of oil for a while and sometimes I don't get around to topping off the oil as soon as i probably should.... So I guess my question is, did the engine throw this code because I hit v-tec with low oil? Or is it something else I should be worried about. Can I just add oil and clear the code and forget about it?
Thanks!
36Chitownrunnin
Jun 17, 2008 08:44 PM
cioli
Jul 31, 2005 12:24 PM
BobGnarly
May 23, 2004 05:28 PM
toooslow
Jul 13, 2003 06:32 PM
