Code reader problem
Old Mar 30, 2007 | 06:03 PM
ir0nmanx's Avatar
Default Code reader problem
I have a problem pulling a code, everytime I use the code reader it gives me an error. I've tried two different code readers, follwed the manual and it still gives me an error sign. The engine light is on but my car still rund perfect. Any help or suggestions welcome.
Old Mar 30, 2007 | 09:54 PM
all-mtr-teg's Avatar
Default Re: Code reader problem (ir0nmanx)
hook up the code scanner with the car's ignition on, it will tell you its linking, then it may tell you to turn the key to off position for a few seconds then turn the key to the ignition position only, don't crank it over. or read the manual to the code scanner, some scanners operate diffently.
Old Mar 30, 2007 | 10:51 PM
ir0nmanx's Avatar
Default Re: Code reader problem (all-mtr-teg)
Yeah, I've done all those and I followed the instructions carefully and still an error sign.
Old Mar 31, 2007 | 02:05 AM
1.8L_allmotormilitia's Avatar
return it back.
Old Mar 31, 2007 | 07:06 AM
Tizight's Avatar
Why don't you jump it with a paper clip and read the codes off the CEL instead?
Zedt3
Honda Civic (2001 - 2005)
Sep 21, 2012 05:27 PM
azlan609
Jan 21, 2010 02:05 AM
Sailor2009
May 8, 2009 02:53 AM
lazyxmofo
Feb 13, 2009 06:43 AM
nighttime
Jul 7, 2004 04:15 AM
