Help!!! Integra Flooded
Old Mar 31, 2007 | 09:16 PM
Boney Ranger's Avatar
Default Help!!! Integra Flooded
The floor in my car keeps flooding every time it rains, but the seats and ceiling don't ever get wet. Help please
Old Mar 31, 2007 | 10:01 PM
nate_2k5's Avatar
Default Re: Help!!! Integra Flooded (Boney Ranger)
check sunroof drain tube, passenger side behind rear seats
Old Apr 1, 2007 | 05:35 AM
Dogginator's Avatar
Daisy... Daisy...
Where is it flooding? I have a piece of plastic floating in my AC condenser that block the drain tube occasionally, which will flood my floor. However, my floor does not flood every time that it rains.
Old Apr 1, 2007 | 08:03 AM
kinick313's Avatar
Default Re: Help!!! Integra Flooded (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Where is it flooding? I have a piece of plastic floating in my AC condenser that block the drain tube occasionally, which will flood my floor. However, my floor does not flood every time that it rains.</TD></TR></TABLE>
I've seen that in numerous honda's... especially 94-97 accords. Most of the time I've seen it happen when the AC is on for at least 5 minutes, you take a turn, and it just spills ALL OVER your feet.
Old Apr 1, 2007 | 08:50 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Help!!! Integra Flooded (kinick313)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinick313 &raquo;</TD></TR><TR><TD CLASS="quote">
I've seen that in numerous honda's... especially 94-97 accords. Most of the time I've seen it happen when the AC is on for at least 5 minutes, you take a turn, and it just spills ALL OVER your feet.</TD></TR></TABLE>
I can ocassionally hear something flapping. The problem occurs when the flapping stops and the drain is sealed. I am simply going to thread a piece of wire up the rubber drain tube to prevent the debris from sealing the hole.
Old Apr 2, 2007 | 06:55 PM
integrawhat's Avatar
Default Re: Help!!! Integra Flooded (nate_2k5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">check sunroof drain tube, passenger side behind rear seats</TD></TR></TABLE>
there should be one on all four corners of the sunroof going down the a and c pillars
Old Apr 2, 2007 | 08:05 PM
H.A.S's Avatar
thats expletive up
Old Apr 2, 2007 | 08:24 PM
aaronhume's Avatar
what year is it? if its a DA then its the seals under the windshield black plastic and directly above the heater blower motor... where does it accumulate first?
mrinno
Mar 16, 2013 01:38 PM
mtownek9
Oct 9, 2007 06:30 PM
not2fast
Sep 4, 2006 10:28 AM
M15
Jun 19, 2006 08:04 AM
bbrian
Feb 17, 2005 12:54 PM
