bent valves????
Old Mar 29, 2007 | 04:52 AM
egboostin6's Avatar
Default bent valves????
so i went to go get a second opinion on why my valves were ticking so loud and automatically lifting @ 3500 rpms. the first guys said they were fine, jus abnormally loud...second opinon said they were bent valves...obviously they need replacment but what else should i replace? are the retainers and springs still usable? i really dont have the funds to completly build my head, i just want it running right! thanks for the help
Old Mar 29, 2007 | 04:55 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: bent valves???? (egboostin6)
How did the valves potentially bend? Did you over-rev the engine? Did this noise suddenly onset?
Old Mar 29, 2007 | 04:58 AM
egboostin6's Avatar
Default Re: bent valves???? (Dogginator)
sorry for the weak discription. i actually bought the car with a obd0 b16, its a 1990 DA.. after throwing a rod throught he block, i decided to put the head on an ls block. even with the b16, the valves were loud...after swapping the blocks, i brought it for a valve adjustment for two reasons, one: just swapped the head, and two: they were really loud and didnt osund right. so i guess theyve been bent..i just want to really know if i should replace any other internals?
Old Mar 29, 2007 | 04:59 AM
Dogginator's Avatar
Daisy... Daisy...
Perform a compression test. It will quickly diagnose bent valves.
Old Mar 29, 2007 | 05:00 AM
egboostin6's Avatar
and if they are?
Old Mar 29, 2007 | 05:07 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egboostin6 &raquo;</TD></TR><TR><TD CLASS="quote">and if they are?</TD></TR></TABLE>
You'll have low compression in at least one cylinder. You will then have to pull the head. Sorry.
Old Mar 29, 2007 | 05:20 AM
egboostin6's Avatar
i realize that, but what would i have to replace? just the valves or the retainers and springs aswell?
Old Mar 29, 2007 | 05:28 AM
Dogginator's Avatar
Daisy... Daisy...
Typically you replace just the bent exhaust valves. Bent intake valves are rare. If you are planning on upgrading springs and retainers, that would be a good time to do it.
You still need to confirm that you have bent valves. Does the car run poorly at low RPM and misfire at idle?
Old Mar 29, 2007 | 06:41 AM
egboostin6's Avatar
at low rpms, the idle jumps around and kinda bogs until i get passed 2000 rpms, then seems to run normal (still loud and liftin completely after 3500)... this also only happens when the vehicle is warm...
jceltalentoso
14
Jan 20, 2012 03:45 AM
jceltalentoso
Jan 18, 2012 10:23 AM
b20integrapower
Feb 9, 2006 07:12 PM
bluegdx16
Feb 17, 2005 06:59 PM
speedymon
Mar 22, 2002 09:40 AM
