idle problem...need help pleas
i just bought a 95 4 door rs, n wen i turn it on it idles like at 3k n then after a min it drops to 1k then raises back up to 2k n so on. it dosent keep a steady idle at any rpm. the motor was pieced together from junk parts, the throttle body is off a 92 n i think the gasket was re-used w sum of dat make ur own gasket crap, idk if that will expletive it up that much??? it was also converted from auto to manuel a while back. i need it to pass smog but i got sum work ahead of me. any input is appreicated. thanks
You can take some starter fluid and spray it around the throttle body to see if the idle changes/surges. If it does, its a vacuum leak causing your problems. Also make sure all your vacuum lines are hooked up correctly. You can also clean the IACV and FITV.
thanks man. anybody selling a throttle body? i also need a stock intake cuz im runnin open throttle
Modified by dmpd_ef at 5:38 PM 3/30/2007
Pashpacino
Engine Management and Tuning
Mar 13, 2018 06:23 PM
bmxfelon420
Mar 20, 2010 04:11 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
