Engine code....again
Old Apr 21, 2007 | 01:16 PM
sickofitall1113's Avatar
Default Engine code....again
P0420 catalytic system performing inefficiently. it came up on bank 1
could be o2 sensor....but i just replaced it with a direct fit brand new one. what else could it be...how to identify.
also: p1457 evap system. this code i thought i fixed when i got a new evap canister. i passed inspection and the CEL went off. a while later it comes back on with the same code.....what the expletive...getting to the end of my rope.
Old Apr 21, 2007 | 02:06 PM
Jtuned DC2's Avatar
* B A N N E D *
i think that means your catalytic converter is crapping out.(filled with garbage) When was that last time you got it replaced?
Old Apr 21, 2007 | 04:06 PM
its never been replaced. 149,000 miles. its still the one from the factory im sure. could i hollow it out or something? how do you do that
Old Apr 21, 2007 | 04:32 PM
onesikdb8's Avatar
Default Re: (sickofitall1113)
P0420 - Catalyst system efficiency below threshold - Problem: Catalytic Convertor or Secondary 02 sensor
Solution: More than likely your Cat if you've replaced your secondary 02 already. Do not hollow it out if you are going to go through emissions.
P1457 - Evaporative Emission Control System Leak Detected - Problem: Vacuum Connection, EVAP control canister, Fuel Tank Pressure Sensor, EVAP bypass solenoid valve, EVAP two-way valve, EVAP control canister vent shut valve, Fuel Tank, EVAP purge control solenoid valve.
Solution: lots of testing....start with the obvious and check for vacuum leaks with carb cleaner, most of the time when I've seen this code it is usually the EVAP purge control solenoid valve.
Good luck!
Old Apr 22, 2007 | 07:26 AM
Default Re: Engine code....again (sickofitall1113)
ok yea, my gas milage now sucks too. is there a way to clean out the cat? the bank 1 o2 sensor is brand new...like 2,000 miles old. is there a way to unclog the cat, if thats the problem? i dont care about emissions, i already passed for this year
Old Apr 22, 2007 | 12:23 PM
help...
Old Apr 22, 2007 | 01:55 PM
in10ceCiviC's Avatar
the honeycomb is the cat is all crapped out probaly , jus change it , my cat went out on my gsr around the same miles as yours ...i jus paid for a performance high flow cat.......was solid....
Old Apr 22, 2007 | 02:27 PM
ok i'll try it
and how long is the stock converter so i can get the right length. i want to just take out the one i have, its bolt on, and put the new one in without a shop or anything
oh, and im looking at this one, what do you think?
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Apr 22, 2007 | 06:13 PM
anyone...
Old Apr 24, 2007 | 11:55 AM
onesikdb8's Avatar
I think Random Technologies makes bolt on High flow cats or check with K-teller.
Ra GS-R
Jul 4, 2007 06:35 PM
chomorro
Jun 26, 2006 10:24 AM
reithhikaru
Jun 19, 2004 12:31 PM
