Super low IAT (Intake Air Temp) sensor reading.
Any ideas what would cause my IAT's to be showing "-40F"?
I'm running a stock OBD-II ecu in my GSR, and reading the data with an Auto X Ray OBD scanner. I rebuilt the engine about 5 months ago and at first the IAT's were realistic. They were pretty relevant to the outside temp. and would slowly increase as the engine warmed up.
A few days ago I changed the timing belt because I accidently got a bit of oil on it, and immediately after, the IAT sensor decided I lived in Antarctica. I did reset the ECU, otherwise the car seems to be running stellar.
Any ideas? Possible bad sensor?
Re: Super low IAT (95 integra)
Tried what you said and the reading was the same. The lowest possible reading is -40F.
I checked continuity and the sensor is fine. Turns out the wire was broken for some reason. Replaced it and problem resolved.
Re: Super low IAT (SoTexDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoTexDC2 »</TD></TR><TR><TD CLASS="quote">Tried what you said and the reading was the same. The lowest possible reading is -40F.
I checked continuity and the sensor is fine. Turns out the wire was broken for some reason. Replaced it and problem resolved. </TD></TR></TABLE>
Just wait until that snapped wire is the one running to your injector and you're like....wtf, why is my car running on 3 cylinders.
LuckyJDM
12-08-2012 10:28 PM
