OBX high flow cat
anyone know anything or used this?
http://cgi.ebay.com/ebaymotors...wItem
its cheap but all i wanna know is if it will get rid of my p0420 code for bad cat efficiency
well it says how the gases that go through the exhaust are turned into something else. the text pipe doesnt do that at all.
A catalytic converter consists of an insulated chamber containing pellets of catalyst through which the exhaust gases are passed. Hydrocarbons and carbon monoxide from the exhaust are converted to water vapor and carbon dioxide. It can increase air flow and performance.
that part. well whatever i already ordered it...do you think it will make the CEL go off or should i just pull the bulb
The first o2 sensor is what actually helps to control how much fuel is put in. The 2nd one is just there to make sure that the cat is working, and does not affect gas milage at all. It will give you a CEL thinking that your cat isn't working (which it obviously won't be with a straight pipe), but if you trick it into thinking the exhaust is fine then the CEL will go away without affecting milage.
Audio28
Nov 16, 2002 03:38 PM
