Overheating problem.
Old Apr 24, 2007 | 10:33 AM
moosta936's Avatar
Default Overheating problem.
Alright well recently my car has been overheating when i go at slower speeds or am at a complete stop. Once i pick up and start moving again it goes back down to normal. Im guessing that it's because my cooling system is clogged with something and i need a radiator flush to completely clean it out so that my thermostat can open up all the way. Just a guess and if that could be problem, anyone know good places for a radiator flush, what the cost is, and will it clean it thoroughly? thanks guys.
Old Apr 24, 2007 | 12:09 PM
Sam92Teg's Avatar
Default Re: Overheating problem. (moosta936)
Check to see where your coolant level is and if your fans are operating properly.
Old Apr 24, 2007 | 12:19 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Most likely your thermostat is stuck closed. You'll need to replace the thermostat, about $15-$20 for an OEM one from a dealer. I used a 99-00 Civic Si one in my car, same part, because the Honda dealer was closer.
For flushing, follow my directions I made in a post a few years ago:
https://honda-tech.com/zero...85746
Then read this which I added later:
https://honda-tech.com/zero...46147
Old Apr 24, 2007 | 03:00 PM
moosta936's Avatar
yea i recently replaced my thermostat, i did a flush today at jiffy lube just before i came back to this so that's taken care of. i think it's worked out well but we'll have to wait and see. thanks for the help.
hondanewbie8181
Honda Civic (2001 - 2005)
12
Dec 16, 2009 03:56 PM
o0ohaviko0o
17
Oct 30, 2008 08:32 AM
P1mpSlap
Jun 18, 2003 08:15 AM
intekragsr
Feb 5, 2003 02:19 PM
