integra dash question
Old Apr 24, 2007 | 09:14 AM
jdm_dc_199's Avatar
Default integra dash question
well, i have a 95 integra w/ tan interior and planning to change it out with black interior. i bought a dash from a 99 integra and i heard that the 94-97 and 98-01 integra dashes are different. can someone confirm if thats true or if there is any way that the 99 dash will work in my 95 integra?
thanks.
Old Apr 24, 2007 | 09:16 AM
mac_24_seven's Avatar
Default Re: integra dash question (jdm_dc_199)
How did you hear they were different?
Old Apr 24, 2007 | 09:22 AM
jdm_dc_199's Avatar
i think someone on T-I said that. they look the same but the plugs or wiring was different. it was a while ago where i read it, so im not sure if it was true or not. or if there all the same.
litovi3tboi503's Avatar
only thing different is the climate control. but youll be fine dont worry about it
Old Apr 24, 2007 | 09:24 AM
Default Re: (jdm_dc_199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_199 &raquo;</TD></TR><TR><TD CLASS="quote">i think someone on T-I said that. they look the same but the plugs or wiring was different. it was a while ago where i read it, so im not sure if it was true or not. or if there all the same.</TD></TR></TABLE>
The dash has no wiring to it.. the only wiring you have is the climate control. air bag steering wheel. and the gauge cluster which you put ur old on in.
Old Apr 24, 2007 | 09:30 AM
jdm_dc_199's Avatar
so if i was to just change out the dash harness with the old one, i should be fine?
Old Apr 24, 2007 | 09:33 AM
theres a write up on doing a tan- black dash swap on here do some more research man. All the wires are the same your older climate control will fit right in no problem. make sure when you get the airbags that theyre the right year because the obd2 and obd1 air bags have different clips.
Old Apr 24, 2007 | 09:38 AM
jdm_dc_199's Avatar
i saw the write up, but before i did the dash conversion, i wanted to see if there was anything different between the 94-97 and 98-01 dashes.
Old Apr 24, 2007 | 09:39 AM
like i said uptop nothing dramatic if any. It will go in just perfect.
Old Apr 24, 2007 | 09:42 AM
jdm_dc_199's Avatar
ok thanks for the help and info.
maxwellmercer
Nov 11, 2008 04:05 PM
reckdrummer
Apr 28, 2008 08:54 PM
JDMPaulWall
Jan 26, 2007 03:44 PM
AIWFCIATR
Sep 20, 2004 11:07 AM
PDM
10
Jun 12, 2004 01:54 PM
