Tires...
Old Apr 24, 2007 | 05:10 PM
guero2craze's Avatar
Default Tires...
I currently got some 15x6 fat fives...wats the widest tire that will fit this? and wat tire do you recommened? somethign with peformance and a good treadlife...
Im currently eyeing the BF Goodrich g-Force Sport...215/50R15
Old Apr 24, 2007 | 05:12 PM
crispy93's Avatar
i had some falken ziex tires in 215/50R15 on my fat fives and i loved them
Old Apr 24, 2007 | 05:25 PM
mrdeadman's Avatar
They let me pick
Default Re: (crispy93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispy93 &raquo;</TD></TR><TR><TD CLASS="quote">i had some falken ziex tires in 215/50R15 on my fat fives and i loved them </TD></TR></TABLE>
215's on stock rims... damn.
I have 205's
Old Apr 24, 2007 | 05:33 PM
nate_2k5's Avatar
Default Re: (mrdeadman)
215's might rub depending on drop, to stay safe go 205
Old Apr 24, 2007 | 06:38 PM
Default Re:
My drop is some konis/HR Sport springs...will the 215/50 15 rub?
Old Apr 25, 2007 | 05:34 AM
Default Re:
bump
Old Apr 25, 2007 | 06:01 AM
nate_2k5's Avatar
Default Re: Re: (guero2craze)
just get 205 to be safe, its not like you gain massive performance by goin 215
Old Apr 25, 2007 | 07:52 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Re: (nate_2k5)
215/50-15 will rub, at least occasionally. If the wheels are on an Integra, stick with 195/55-15 or 205/50-15.
Differences in performance between models of tire - due to softer compounds and tread design - are just about always much, MUCH more important than differences in treadwidth.
For example, a Falken Azenis RT-615 in 205/50-15 will give you MUCH better grip on dry pavement than a g-Force Sport in 215/50-15. And if you need a longer-lasting tire (or one that's better in rain), a Kumho SPT or Yokohama ES100 in 205/50-15 will also give you much better grip than a g-Force Sport in 215/50-15.
Is this for an Integra, or are the wheels on some other model car?
Old Apr 25, 2007 | 10:17 AM
Default Re: Re: (nsxtasy)
the tires are on an 94 integra
Old Apr 25, 2007 | 11:04 AM
nsxtasy's Avatar
H-T Order of Merit
Here's what I suggest.
If you care ONLY about the maximum grip on dry pavement, such as if you plan to use these for an occasional autocross or track event, get the Falken Azenis RT-615 in 205/50-15, $73/tire. It's the stickiest street tire you can get on dry pavement. Downsides include short treadlife (typically 10-12K miles) and so-so wet traction.
If you also care about wet traction and/or long treadlife, such as for daily driving, get the Kumho SPT or Yokohama ES100 in either 195/55-15 or 205/50-15. Both have pretty good dry traction, excellent rain traction, and last a reasonably long time (25-40K miles). ~$55-60/tire.
Any of these options will give you MUCH better performance than the BFG g-Force Sport, even in 215/50-15 (which will rub).
You can find more detailed recommendations in this post.
Old Apr 25, 2007 | 11:52 AM
mc-integra111's Avatar
Default Re: Tires... (guero2craze)
Check with each tire manufacturer about their respective tires. I have mounted 225/50 Toyo RA1's on my 14x6 rims on a 90 Integra.
Old Apr 25, 2007 | 02:32 PM
usmarinedelta's Avatar
* B A N N E D *
wait a minute, so 205/50-25 will fit on my 94 gsr fat fives which currently have 195/55 15? Cause I went to a shop that had a sale and they said they didn't carry 195/55 15's.
Old Apr 25, 2007 | 03:05 PM
IntegraDOHCter's Avatar
I'm a tire sales rep...I've ran kuhmo for years on all my cars. Tryed alot of other ****,and keep coming back to those damn kuhmos, I love 'em
Old Apr 25, 2007 | 03:12 PM
* B A N N E D *
bump need answer.
Old Apr 25, 2007 | 03:30 PM
rayray NOT shanaynay's Avatar
Default Re: (usmarinedelta)
a lot depends on the brands because when i was shopping around, not too many companies make that certain size. i run khumo spt's 205/50/15's and they're perfect. especially with my drop.
Old Apr 25, 2007 | 03:50 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usmarinedelta &raquo;</TD></TR><TR><TD CLASS="quote">so 205/50-25 will fit on my 94 gsr fat fives which currently have 195/55 15?</TD></TR></TABLE>
Assuming you meant to type 205/50-15, and you don't really have 25-inch wheels...
Yes, absolutely. Most 205/50-15 tires are approved for mounting on wheels 5.5-7.5 inches wide, so they're fine on the 15x6 fat fives. Their diameter is 1.6 percent smaller than 195/55-15, so they will make your speedometer read higher by that percentage, which is not a huge difference. 205/50-15 will not rub.
Old Apr 25, 2007 | 05:13 PM
thewrai6th's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">215/50-15 will rub, at least occasionally. If the wheels are on an Integra, stick with 195/55-15 or 205/50-15.</TD></TR></TABLE>
Occasionally as in during braking and cornering, or making a u-turn?
I was looking forward to a bit wider tire, as I had 205's on my Civic.
BradleyJP
Mar 17, 2009 06:24 AM
ITR010342
Jan 30, 2009 02:29 PM
88ED8
Feb 11, 2006 11:16 AM
Robstunner4
Jul 20, 2004 07:39 AM
Dveloped
Dec 27, 2003 06:14 PM
