itr headlight conversion
Old Apr 21, 2007 | 06:21 PM
g0tgot's Avatar
Default itr headlight conversion
i am stuck, my low beams on my itr headlights have no power to the drivers side....does anyone know the color of the low beam wire for the drivers side on a 99 integera>>?? either there is a fuse i cannot locat ( i have replaced a few) or i dont know wich wire is hot under the hood for install.......please clarify!!
Old Apr 21, 2007 | 06:29 PM
94rs-turbo's Avatar
hid? or non hid?
https://honda-tech.com/zerothread?id=1116085
https://honda-tech.com/zerothread?id=105247
Old Apr 21, 2007 | 06:49 PM
g0tgot's Avatar
Default Re: itr headlight conversion (g0tgot)
non hid for now, i am going to get a conversion kit once i get some more spending $$$ i still dont have an actual idea of why i cant get my drivers side headlight to work.... the only wire that I can seem to use is the high beam wire. there are about 5-6 wires coming out of the harness, 2 ground and 3 diff powers, only one is hot and it only works when i put my high beams on.........as for the passenger side, there are 4 wires 2 ground and 2 poer (one for low beam and one for high beam) if anyone has anything to help me it would be much appreciated........been working on this for 2+weeks now......no break in the wire at all.........and i dont have a diagram for my internal fuse box, wich dioesnt help the situation.
Old Apr 21, 2007 | 06:55 PM
94rs-turbo's Avatar
well the low beams are the exact same plug as the stock dc2 strait plugs on. The only way it wouldnt work is if you lost the power to the wire or its not grounded correctly
Old Apr 21, 2007 | 06:59 PM
g0tgot's Avatar
i know i have great ground......it works with the high beams.......I just need to distinc wich color wire is the low beam then go from there
Old Apr 21, 2007 | 07:12 PM
94rs-turbo's Avatar
red w/ either black or yellow strip you shoundnt have ever needed to cut it though
Old Apr 21, 2007 | 07:25 PM
g0tgot's Avatar
Default Re: (94rs-turbo)
meh minor accident with fendor + headlights when wiring was ripped and tangled by the time it got to the body shop, and then i did the itr conversion when i repaird it so now i have alarm/headlight/sidemarker wiring tangeld.....
Old Apr 21, 2007 | 11:45 PM
98GSRDC2's Avatar
Default Re: (g0tgot)
fusebox= left side under steering column.
Old Apr 22, 2007 | 08:17 AM
g0tgot's Avatar
Default Re: (98GSRDC2)
i know where the fuse box is located i just dont have a diagram for wat fuse is for what accessorie YaDiDaMeAn>?
crist488
Sep 14, 2009 02:22 AM
chairwitharmrests
Lighting
Sep 3, 2008 12:48 PM
BB6racer
Sep 14, 2005 11:56 AM
hondeducation
Jan 25, 2004 09:42 PM
