Ignitor??
Old Sep 18, 2007 | 06:37 AM
wstsydr's Avatar
Default Ignitor??
Hey guys, i searched all i had time for and my question has prolly been covered, but anyways, here goes, I have a 97 Integra GS, it gets spark, it gets gas, i tried to spray starting fluid into the IM and got nothing. The spark could be weak if that is possible, but there is spark so i dont suspect my ECU or any other controller to be at fault since that should be an all or nothing deal. Wires are good, i tested their resistance. I am down to the problem being the ignitor, the cap, or the rotor.
Mainly wanting your opinions on the matter or if you guys think it could be something else. If you have any other questions about my set-up ill answer them as best as i can, but my ignition and fuel system are bone stock.
Old Sep 18, 2007 | 06:39 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Ignitor?? (wstsydr)
You can test an igniter, you just need a helms to tell you the specs it should be at. Testing that should be your first step make sure the coil and everything else is good inside the distributor also.
BarebonesB18
Mar 7, 2018 05:16 PM
ex_ricer
Aug 14, 2008 02:14 PM
wiseguyoncouch
Jan 30, 2008 09:47 AM
JDM_EK4_Coupe
Apr 10, 2007 06:05 AM
Kamin
Jul 31, 2003 07:45 AM
