engine flooded wont start please help !!!!!!!!!!!!!
Old Sep 20, 2007 | 10:47 AM
dboz3403's Avatar
Default engine flooded wont start please help !!!!!!!!!!!!!
ok i have a 96-99 gsr running a p28 ecu in it . I bought the car from a friend last night and drove it home car ran great when i got to his hous the car started right up . he said first thing in the morning whe its cold the car has a hard time staying started. if you hold the gas pedal down a bit to keep the rpm's up the car is fine for the rest of the day after that . The car does have a fuel cut off switch which i turned off due to the fact i live in a high crime area. This morning i go out to get in it and start it up and it starts and then dies about 2-3 times i got it briefley started and then it died again . I tried cranking it and cranking it but no dice it wont start so i pulled the plugs out and disconected the injectors and tried to see if the car was flooded ( i could smell gas) I looked into the compustion chamber and the tops of the pistons looked damp . i put everything back together and left it and went to work . is letting the car sit going to help it ? what do i need to do help please thank you
Old Sep 20, 2007 | 11:07 AM
Schister66's Avatar
Man U FTW
Default Re: engine flooded wont start please help !!!!!!!!!!!!! (dboz3403)
Try the following steps
1. Hold the gas pedal to the floor
2. Crank the engine a few times
3. Let the gas pedal go and try it again
when you hold the pedal to the floor, the TPS will cut the fuel injectors since the throttle is wide open. This is called "clear-flood mode."
Old Sep 20, 2007 | 11:27 AM
dboz3403's Avatar
is this a common proble will this fix the issue . by the time i get home the gar would have sat there for about 9 hours should it start when get home or will it have the same issue ????
Old Sep 20, 2007 | 11:43 AM
dboz3403's Avatar
will the gas evaporate with the plugs in it sitting for niune hours
Old Sep 20, 2007 | 12:25 PM
__oversea's Avatar
Default Re: engine flooded wont start please help !!!!!!!!!!!!! (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Try the following steps
when you hold the pedal to the floor, the TPS will cut the fuel injectors since the throttle is wide open. This is called "clear-flood mode." </TD></TR></TABLE>
i like sound of this.
Old Sep 20, 2007 | 04:36 PM
95 integra's Avatar
Default Re: engine flooded wont start please help !!!!!!!!!!!!! (__Stig)
That little amount of gas will evaporate in a matter of minutes. Generally its nearly impossible to flood a car because the spark plug will eventually put the fire to it....however I have had my spark plugs covered so badly in carbon buildup from "flooding" that they wouldnt spark. I would suggest fixing the problem which sounds like you havea bad base map loaded in the ecu.
Old Sep 20, 2007 | 07:58 PM
integra3586's Avatar
integra's to the best of my knowledge are not equiped with this. MAYBE on the older ones. but i know for a fact my car will start if i floor it while cranking. a lot of american cars have that feature. its lots of fun to mess with people when you are driving there car.
i have a 2001 integra
Old Sep 21, 2007 | 06:28 AM
r1ch1e's Avatar
Default Re: engine flooded wont start please help !!!!!!!!!!!!! (integra3586)
i have the same freaking problem in my ef with a y8 running a p28. i got spark injector are good and fuel. so it all comes down to my p28 computer? you think did a comp test on my y8 and it got 90 then 105 acroos the board. sorry not trying to jack this thread but we are in the same situation.why post twice
Old Sep 21, 2007 | 06:33 AM
r1ch1e's Avatar
Default Re: engine flooded wont start please help !!!!!!!!!!!!! (r1ch1e)
you check you cap and rotor?
Old Sep 21, 2007 | 06:37 AM
dboz3403's Avatar
cap was worn could deffenately see some build up . rotor also . tonight i am going to try and replace cap , pugs , rotor , and test the dizzy to see if it is working any help would be great .Thanks all
Psykomantis00
11
Feb 25, 2014 04:52 AM
mkeacura
Sep 17, 2013 06:17 AM
explosive
Aug 21, 2009 04:30 AM
Azxster
Oct 8, 2007 05:01 PM
siregcivic
Aug 13, 2005 08:48 AM
