Vtec problem HELPPP!!! weird!!
Old Sep 17, 2007 | 05:37 PM
hondarny's Avatar
Default Vtec problem HELPPP!!! weird!!
i have a 98 gsr 9 (stock) the car its actin weird, vtec stops workin once in a while. check engine will go on and vtec stops workin, so i go and unplug the battery and plug it back on and still doesnt work but no check engine, while drivin sometimes vtec works, and when the vtec doesnt work the motor sounds different, intake noise gets louder, so far nobody could fix the problem so i was wonderin if u guys know wat the problem might be
Old Sep 17, 2007 | 05:57 PM
1uncleanDA's Avatar
Default Re: Vtec problem HELPPP!!! weird!! (hondarny)
So you didnt check your CEL??
posHonda's Avatar
why dont you go check that code instead of just unplugging the battery and plugging it back in? you could have some low oil pressure.
Old Sep 17, 2007 | 06:45 PM
hondarny's Avatar
Default Re: (iVteC_PoWeR)
cel?
Old Sep 17, 2007 | 06:53 PM
posHonda's Avatar
CEL=Check Engine Light
b18c1ej8's Avatar
Default Re: (hondarny)
check engine light, you sure your not mistaking this "problem" for your secondaries coming on
Old Sep 17, 2007 | 07:12 PM
hondarny's Avatar
Default Re: (b18c1ej8)
i checked it, but it gave me code 8 which is distributor, BUT dizzy its new so yea
Old Sep 17, 2007 | 08:59 PM
bowser_cd5's Avatar
did you check your vtec fluid?
Old Sep 17, 2007 | 09:01 PM
wegotmorrison's Avatar
Default Re: (bowser_cd5)
You wanna know what I would do? I would take it to HONDA. haha. I can change change a spare tire, and oil.. I wish I could work on my car like all you lucky bastards...
Old Sep 18, 2007 | 04:02 PM
JDM5075's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bowser_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">did you check your vtec fluid?</TD></TR></TABLE>
is Vtec fluid right beside the pixie dust and magic lattern on the gold plated firewall? hahaha
Seriously tho, there is no such thing as Vtec Fluid, sadly some people just suck at life....I had this same issue with my '01 GSR, my CEL comes on if I stay in Vtec for a long period of time....usually 5 min of just cruising around 4600rpm....i found out my motor was loosing oil pressure (crucial for Vtec engagement)
check your oil, 95% of Vtec problems are oil issues(this is what my Honda dealer told me)
also if you want to check everything...take off the Vtec solenoid and clean the filter, sometimes a little dust can get in there and mess things up....this happened to my friends '00 GSR
Old Sep 18, 2007 | 04:42 PM
Teufeldog's Avatar
Default Re: (JDM5075)
The ECM/PCM has to have these prerequisites before it will allow the VTEC solenoid to activate:
Vehicle Speed
RPM
Engine Coolant Temp.
Oil Pressure
Throttle Position
Also, if you have a CEL it won't work either. If you can make sure that all of these sensor are reporting to the ECM/PCM correctly, then you can start looking for some kind of mechanical problem/interference (dirt on the spool valve screen, blockage in the oil passages etc...) I am not sure what code 8 is on an OBDII Integra, but I would get the code checked by Acura or someone that can tell you what code it is. Should be like a Pxxx. Hope this helps.
Modified by Teufeldog at 1:56 AM 9/19/2007
01em2slvr
Honda Civic (2001 - 2005)
Nov 11, 2009 12:43 PM
gsrboost737
Aug 7, 2008 06:38 AM
Phantastic
Nov 13, 2005 11:45 AM
veilsides2000
Nov 27, 2004 11:18 PM
95 GSR B20VTEC
Jul 25, 2002 01:08 PM
