piston question
Old Sep 17, 2007 | 04:27 PM
touintegra's Avatar
Default piston question
i'm currently in the process of doing a LS-V motor, with a fully rebuilt gsr head.....i want to know if i put aftermarket piston on stock rods will that be a good idea. cause i'm limited on money....i'm going all motor don't plan to rev my motor past 8000 rpm.....whats the bad and the good in the long run.
Old Sep 17, 2007 | 04:48 PM
myfirstdc2's Avatar
Default Re: piston question (touintegra)
yea thats fine i do it all the time. but if u use forged pistons then u might wanna do forged rods.
Old Sep 17, 2007 | 04:52 PM
touintegra's Avatar
Default Re: piston question (myfirstdc2)
what kinda piston do you reccomend.....i want some high compression, how high can i go for a gsr head....i have rev hard flat high comp valves and sk2 valve springs and etc......any suggestion would much be appreciated.
Old Sep 17, 2007 | 05:04 PM
karma28217's Avatar
A friend of mine used B16a pistons with stock rods in his Ls/vtec. They're oversized by .5 mm for a larger bore and higher compression
Old Sep 17, 2007 | 05:09 PM
touintegra's Avatar
Default Re: piston question (karma28217)
i have a cousin who used ctr piston and his car ran like **** even after a dyno....just don't trust stock pistons.
Old Sep 17, 2007 | 06:03 PM
Ketone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by touintegra &raquo;</TD></TR><TR><TD CLASS="quote">i have a cousin who used ctr piston and his car ran like **** even after a dyno....just don't trust stock pistons.</TD></TR></TABLE>
the compression ratio is pretty high on ctr pistons, so depending on the tune, no wonder why your cousins car did not run well. Stock pistons are fine if you are on a buget, just need to choose the right stock piston for your application
To answer your question, you can run forged pistons on stock rods, but if you are going to spend all that money rebuilding your motor, aftermarket rods might not be a bad idea for some extra insurance.
Old Sep 17, 2007 | 06:49 PM
myfirstdc2's Avatar
if u looking for a nice budget internal try using either p73 or p30s. depending on what u want there is a lil machining required. those will be good for a gsr combo. pct's wil lnet around 12.5:1 and will run good if u can tune it correctly if not u run in to some trouble like higher octane etc etc .
Old Sep 18, 2007 | 04:48 PM
touintegra's Avatar
thanks for all your info and suggestions, when i do decided which setup to go with the ls-v i'll post up a topic and tell you guys whats going on.....by the way do you guys know the torqe specs for ls rods....i got the book but just wanna check to see if its right.
Old Sep 18, 2007 | 04:57 PM
myfirstdc2's Avatar
23lbs
92CHB
Oct 10, 2011 07:36 AM
NOTDISFA5
15
Sep 26, 2010 06:27 PM
BLK99VTECR
Jan 19, 2005 06:40 PM
Boostage
Oct 18, 2004 08:09 AM
smnowell
Oct 11, 2002 01:10 PM
