various question
Old Sep 18, 2007 | 06:58 PM
soon2bdropped's Avatar
Default various question
1. what does shotpen means
2. what does clay the motor.. check for clearance issues?
3. i wanna spray 75 shots of nitrous on ls motor. wet i want to read up on how its wired up and how it works, where do igo.. doesn't work on this section. let me know thanks guys.
would 75 shots hold on ls that has new valvetrains... would i need to do, rod bearings and definately piston rings.. let me know thansk
Old Sep 19, 2007 | 03:10 AM
Default Re: various question (soon2bdropped)
BUMP...
ALSO I HEARD BACKFIRE WASHES THE CLYINDER WALLS WHAT DO THEY MEAN BY THAT?
Old Sep 19, 2007 | 07:20 AM
AWD Terror's Avatar
Look in the FI(Forced Induction) section
https://honda-tech.com/zeroforum/49
Old Sep 19, 2007 | 07:35 PM
Default Re: various question (AWD Terror)
how does that link help me with any of my questions here?
Old Sep 19, 2007 | 08:45 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">1. what does shotpen means
would 75 shots hold on ls that has new valvetrains... would i need to do, rod bearings and definately piston rings.. let me know thansk</TD></TR></TABLE>
1. Shotpeening is the blasting of something with steel ***** of a controlled size at a controlled velocity. It cold-works the metal surface, refining the grain, making it stronger.
2. Claying refers to using clay on the valve reliefs on the piston and then installing the head and cams and turning the motor over by hand to determine how much piston-valve clearance you are working with.
3. You're on your own for this one. A 75 shot by an inexperienced person on a stock motor spells disaster. You probably want to ask this specific question in the FI forum.
Old Sep 20, 2007 | 02:59 AM
Default Re: various question (Dartanian)
how can u tell how much clearance... u than take head off and see if the valve touch the clay?
Old Sep 20, 2007 | 06:18 AM
Dartanian's Avatar
Pretty much. You can take a set of calipers and measure exactly how far into the clay the valve went.
luvmihatch
Mar 31, 2008 08:47 PM
jdmrex90si
10
Dec 26, 2007 11:15 AM
JDM978
Jan 25, 2005 04:07 PM
JdmLsPwr425
Jun 24, 2004 09:19 AM
untitled
Jun 6, 2003 02:18 PM
