lsd!!! :D
Old Sep 18, 2007 | 09:12 PM
mcc361's Avatar
Default lsd!!! :D
what car's trannys come with lsd? i have a 95 gsr and i want to know if i have lsd OTHER THAN burning out! i also have no time to get my fatass under the car to check to see if it says lsd so any help??
Old Sep 18, 2007 | 09:17 PM
SLEEPER775's Avatar
Default Re: lsd!!! :D (mcc361)
usdm itr, jdm itr/ctr. not sure about the others.
Old Sep 18, 2007 | 11:11 PM
Junkie's Avatar
Doing a burnout isn't a good way to tell. With some pretty shitty tires I left a 30' pair of stripes in my DA, with an open diff.
Old Sep 18, 2007 | 11:57 PM
alexisthemovie's Avatar
you should be able to tell by the way your car leaves off the line. with an lsd, the car will track perfectly straight. with an open diff, your steering wheel will tug both ways a little bit.
Old Sep 18, 2007 | 11:59 PM
ek_sick's Avatar
lsd is sickk
Old Sep 19, 2007 | 04:26 AM
Dogginator's Avatar
Daisy... Daisy...
Your 95 GSR did not come with an LSD stock.
Here is a check thread:
https://honda-tech.com/zero...63432
Here is a transmission infromation thread:
http://www.ff-squad.com/tech/temp/Bgears.htm
Old Sep 19, 2007 | 04:59 AM
Doostur's Avatar
ITR FTW. Cant live without LSD. Search next time, its been covered 9873243 times
Old Sep 19, 2007 | 07:44 AM
Junkie's Avatar
Default Re: (alexisthemovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to tell by the way your car leaves off the line. with an lsd, the car will track perfectly straight. with an open diff, your steering wheel will tug both ways a little bit.</TD></TR></TABLE>There are FWD cars with LSDs that have torque steer.
Old Sep 19, 2007 | 09:03 AM
Default Re: (Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkie &raquo;</TD></TR><TR><TD CLASS="quote">There are FWD cars with LSDs that have torque steer. </TD></TR></TABLE>
this is true as in the case of a mazdaspeed3 or a high torque honda, but on a stock gsr, one would easily notice the difference between an lsd and open differential.
Old Sep 19, 2007 | 12:04 PM
mcc361's Avatar
Default Re: lsd!!! :D (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Your 95 GSR did not come with an LSD stock.</TD></TR></TABLE>
awwww bummer!!!
lsvtec hf
Feb 24, 2009 02:06 PM
jdub db8
Jul 26, 2004 10:55 AM
EFSiR
Jun 23, 2003 10:40 AM
shermanyang
Feb 20, 2003 08:19 PM
