DIFFERANCE BETWEEN LS AND B20 HEAD ?????
Old Sep 17, 2007 | 04:38 AM
DC2_vtak13's Avatar
Default DIFFERANCE BETWEEN LS AND B20 HEAD ?????
Hey honda tech's , im new 2 site and have a few question bout the Ls head and B20 head. What is the difference between both ?? would a B20 head fit on a LS with out any problems ?? the thing is i have a 94 LS and had my head stolen at a local machine shop , they have a B20 head there but not sure if it would fit . thanks for help
Old Sep 17, 2007 | 11:30 AM
g0tgot's Avatar
it will fit
Old Sep 17, 2007 | 11:55 AM
pdotjones's Avatar
Default Re: (g0tgot)
i replaced a b20 with a ls that i had. no problems whatsoever.
Old Sep 17, 2007 | 11:56 AM
myfirstdc2's Avatar
Default Re: DIFFERANCE BETWEEN LS AND B20 HEAD ????? (DC2_vtak13)
it will fit np just need the intake manifold of your ls the b20 stand up to high
Old Sep 17, 2007 | 12:04 PM
dsnyder305's Avatar
The exact same head. The castings are the same (P75), unless yours was a PR4 casting
(which I believe it might be, now that I think about it), and the differences are negligible
between the two. The CRV cams are different, however (less lift AND duration),
meaning they are built more for low end torque so you don't have to rev the **** out of
your motor to get it to go anywhere (CRV's are SUV's, after all). The CRV cams SUCK,
but then again, so do the stock LS cams. Go aftermarket
Old Sep 17, 2007 | 02:08 PM
91redteg's Avatar
there isnt an advantage to putting a b20 head on an ls. there pretty much the same. the block is .2 liters bigger than the ls's thats where the advantage is.
Old Sep 18, 2007 | 06:28 AM
J's 94 Accord's Avatar
Default Re: DIFFERANCE BETWEEN LS AND B20 HEAD ????? (91redteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91redteg &raquo;</TD></TR><TR><TD CLASS="quote">there isnt an advantage to putting a b20 head on an ls. there pretty much the same. the block is .2 liters bigger than the ls's thats where the advantage is.</TD></TR></TABLE>
Heads are the same. Unless the B20 head is stamped P8R.
Old Sep 18, 2007 | 12:29 PM
SIC_jdm_da9's Avatar
i got a b20 head stamped p8r... would it still fit right on a LS block? i was thinking of putting it on there because of the smog over here in CA about b20s.... yeahh smog in cali sucks but hey smell are air lol
Old Sep 26, 2007 | 10:18 PM
SIC_DA9's Avatar
yes our air does smell good. and i want ur head andy. ill buy it. hahah
Old Sep 26, 2007 | 10:27 PM
doood's Avatar
been there done that
Default Re: (SIC_jdm_da9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC_jdm_da9 &raquo;</TD></TR><TR><TD CLASS="quote">i got a b20 head stamped p8r... would it still fit right on a LS block? i was thinking of putting it on there because of the smog over here in CA about b20s.... yeahh smog in cali sucks but hey smell are air lol </TD></TR></TABLE>
it has a larger combustion chamber so you'll drop compression. but it does have vtec size intake valves.
low&slowef
Mar 5, 2011 03:02 PM
SCIVIC94
Mar 3, 2005 06:57 PM
J-Spec EG
May 7, 2004 09:38 PM
Acura_I-RS
Jul 7, 2002 03:40 PM
