B18C5 differences in year
Old Sep 19, 2007 | 02:31 PM
g0tgot's Avatar
Default B18C5 differences in year
what is the difference between the PRE 1996 B18C5 and the 1996 and ^ B18C5 motor, cosmetic looks the same, hp and torque ratings the same.....why are the 96 b18c5 SPEC's more costly?
Old Sep 19, 2007 | 05:20 PM
Padawan's Avatar
Darth ModerVader
Default Re: B18C5 differences in year (g0tgot)
There is no 1996 B18C5. If you're referring to the 96-spec JDM ITR's B18C, my only guess for someone charging more would be the fact that it's a bit rarer than the newer 98-spec B18C's.
Old Sep 19, 2007 | 05:22 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: B18C5 differences in year (Padawan)
96 spec itr's are usually cheaper than 98 spec
98 spec has the 4-1 header and the 99-00 has the more aggressive cams, 98 spec also has a 4.7 final drive compared to the 96 specs 4.4 final drive
Old Sep 21, 2007 | 04:59 AM
g0tgot's Avatar
i am swapping my transmission probbably this weekend , if not today.....i am looking to get into a b18C but the cost is, almost as much as the car is worth itself! i am def not willing to pay $5,000 for 200 ponies......anyone have a better lingk to find these motors for a better price than commercial>?
Old Sep 21, 2007 | 05:10 AM
Dogginator's Avatar
Daisy... Daisy...
The intake camshaft is different.
USDM 97-98: 14111-P73-J00
USDM 00-01: 14111-P73-J01
JDM 96-97: 14111-P73-J00
JDM 98-01: 14111-P73-J01
The throttle body differs on some of the JDM engines as well. All USDM and JDM 96-97 have a 62mm throttle plate. The JDM 98-01 is slightlky larger. As mentioned before, the 98-01 JDM also has a 4-1 header. All USDM and JDM 96-97 has a 4-2-1 header.
Old Sep 21, 2007 | 05:31 AM
nate_2k5's Avatar
Default Re: B18C5 differences in year (Dogginator)
while the 98 spec may have the 4.7 final drive the 96 spec has a shorter 4th which makes the performance almost exact.
Old Sep 21, 2007 | 10:10 AM
rockofcali's Avatar
96 spec 4,500 installed last time i checked...labjunkies.com
team top secret
Nov 28, 2010 03:30 PM
toolbox21
Jan 16, 2010 04:59 PM
vla
Sep 2, 2008 10:13 PM
kool168
Nov 2, 2003 04:20 PM
VoltageLS
Feb 3, 2003 07:31 AM
