will o2 sensor make
Old Aug 2, 2008 | 08:00 AM
hondaman1212's Avatar
Default will o2 sensor make
okay i bought a da stock motor minus turbo. there is no o2 sensor on the car how will this make the car run..the car does run like crap but i was wondering if this is the cause. the guy i bought it from said its a turbo car it doesnt need an o2 which sounded like a rather stupid remark,someone chime in on this. the car seems to lag and run very rich. like i smell like gas when i get out of the car.so can the o2 sensor cause this?
Old Aug 2, 2008 | 11:27 AM
Tegraracer90's Avatar
Default Re: will o2 sensor make (hondaman1212)
is there a place to plug an o2 sensor in at.....and is there a spot to put one in the exhaust?...
**an o2 sensor measures the o2 and co2 ratio in the exhaust..telling the computer if the car is running too lean or rich...which the computer in turn determains how much fuel to inject by also calculating the amount of air going through the throttle body from the MAP sensor***
If there is a place to plug one into and put it in the exhaust pipe i deff would...that could most likely be why your running rich...
also check your MAP sensor..if that is bad it could be telling your computer its passing more air then it actually is...it would make it run rich too... but i think the o2 sensor is your problem
Old Aug 2, 2008 | 12:07 PM
Default Re: will o2 sensor make (Tegraracer90)
i cant find the wiring that comes from the harness to the o2 sensor so im gonna run it back to the ecu. the last idiot who had this car thought things could just be taken out like that. what pins on the ecu does the o2 sensor run off of?thanks for replies
Old Aug 2, 2008 | 02:42 PM
bump i need to know what ecu pin the o2 sensor is on how to run
Old Aug 2, 2008 | 06:33 PM
sorry man that i cant help you with i man i am not that experianced with wiring things to the ecu...BUMP FOR SOMEONE TO HELP HIM
g2tegsown
Jul 1, 2008 08:39 PM
odishaw
Feb 16, 2008 08:34 AM
urquidezj
Jun 19, 2007 10:16 PM
arjusmc
Oct 23, 2003 04:26 PM
tonylude94
Aug 21, 2003 01:26 PM
