type r throttle cable install
Old Aug 2, 2008 | 09:03 PM
Destructive-'s Avatar
Default type r throttle cable install
alright, i installed the type r throttle cable and stay. i used the LS pulley, but used the GSR pulley spring. im getting weird idles, and i think it may be that i used the wrong spring. i took off my piping from the throttle body so i could look inside, and it looks like the butterfly inside the throttle body isnt going 100% shut, when i manually shut it with my fingers, the car idles normally.
what spring should i have used, or is it something else?
people who successfully did the install, help a brother out!
thanks!
Old Aug 3, 2008 | 11:01 AM
Default Re: type r throttle cable install (Destructive-)
up up up
Old Aug 3, 2008 | 11:43 AM
Jintegragsr97's Avatar
I used the CRV spring with the Pulley. IT worked fine. But i think you need the LS spring because when i installed mine and tried to use the gsr spring, it didnt work.
Old Aug 3, 2008 | 02:57 PM
Default Re: (Jintegragsr97)
ok cool ill check into it, thanks
Old Aug 3, 2008 | 03:21 PM
lsvtecboi'95's Avatar
you would have to reverse the GSR spring for it to work since it is the only one that pulls from the opposite direction.. but i would just say get the LS spring
Old Aug 3, 2008 | 07:34 PM
Default Re: (lsvtecboi'95)
alright cool, i already got the ls spring, ill swap it out and let you guys know what happens
vacantskies88
Nov 12, 2014 11:39 AM
Dang EG
Nov 7, 2007 09:55 AM
greenDC2
Jun 30, 2007 12:26 PM
aznwash3wboi
Aug 29, 2005 12:04 PM
HT Chaplain
Apr 27, 2004 03:55 PM
