Type-R engine problem!
Old Aug 1, 2008 | 11:03 PM
tbrown's Avatar
Default Type-R engine problem!
Hi. i bought my car basically how it is...99 civic SI i dont know much but, ill try to explain as best as i can. It had a b18c5 engine swap. among a handful of other things. i noticed about a month back the timing belt had a hole in it. the engine only had about 2,500 miles on it so i was quite amazed. anyway...exactly one week ago i had the belt replaced at a mazda shop....its been running fine except ever since the install its been having trouble idling when i first start it....it keeps dipping below 1 thousand rpm's then goes back to 1 thousand...keeps going back and forth. usually ending up stalling. And its actually stalled on me 2 times while i was driving. anyway, today i was shifting from 3rd to 2nd when i hear a really odd low pitch humming noise coming from the exhaust..as im about to roll to a stop i feel something almost fallout of the engine.. i could feel it in the clutch...but i looked on the road and found nothing. i have no clue as to what it is...but now my cars engine wont turn over. and the timing belt on the front side moves about 1 inch in either direction. plz give me some insight
Old Aug 2, 2008 | 06:43 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Type-R engine problem! (tbrown)
Post some proof that the engine swap is legit.
Old Aug 2, 2008 | 10:51 AM
hondaman1212's Avatar
Default Re: Type-R engine problem! (Todd00)
you can suck his ***** cartman..no one cares if its legal or not i would take my car back to the place that did the timing belt, obviously your belt skipped a tooth or came off the tensioner let the last people that looked at deal with it for right now
Old Aug 2, 2008 | 01:39 PM
Kendall's Avatar
To be perfectly honest, it sounds like it was installed a tooth off on the intake side and the tensioner wasn't torqued properly.
Of course this could be a result of a larger problem. Make sure your cam gears are straight and that you can spin the engine freely with everything bolted up properly. Something like a seized water pump could cause all of those problems and could easily be misinterpreted as shoddy workmanship.
Old Aug 2, 2008 | 02:11 PM
tbrown's Avatar
hmm alright fellas thanks for the insight. hopefully its something along those lines...i hate to of bent a valve or something worse..i appreciate it.
Old Aug 2, 2008 | 02:47 PM
yc_dc4mar's Avatar
Default Re: (tbrown)
to me it sounds like your tensioner wasn't tightened properly or something...does it make a rattling noise?
mazda shop or not..they are retarded if they cant put a timing belt on a honda.
Old Aug 2, 2008 | 09:22 PM
tbrown's Avatar
there was no rattling noise..up until my engine siezed...and the only rattling type sound i heard was the sound of something falling apart.
Old Aug 3, 2008 | 11:44 PM
Ek9LbC's Avatar
ttt
Old Aug 4, 2008 | 02:11 PM
tbrown's Avatar
Turns out one of the cam gears got nicked on almost every tooth. along with that, the belt stretched SOMEHOW probably the belt i ordered was ****...figures. thereby causing the belt to skip a few teeth.basically ended u knocking a valve into the head of the engine...GG time to get a new head
Old Aug 4, 2008 | 04:43 PM
steveo135's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Post some proof that the engine swap is legit.</TD></TR></TABLE>
WTF????
To The OP sorry to hear that.. take it back to the shop and B***h and Moan untill you get a new engine like the one they just ruined for you
to crappy overpriced mechanics
Old Aug 4, 2008 | 06:11 PM
tbrown's Avatar
Default Re: Type-R engine problem! (steveo135)
haha yea.. i wish it was that easy. unfortunatly they wont take responsibility.. and its really not there fault. so guess im just gonna have to get a new head. and maybe some pistons dunno
CaliforniaSnow
Feb 12, 2014 08:00 PM
christiankirana
13
Jul 29, 2009 10:21 PM
tbrown
Aug 7, 2008 04:37 PM
HS2G
Aug 11, 2006 11:11 PM
2002_SE
Aug 24, 2005 03:35 PM
