tranny problem
Old Aug 6, 2008 | 11:11 PM
dc2[HI]'s Avatar
Default tranny problem
well i have a gsr with a si trans, the problem is that my passenger side axle keeps popping out and is leaking through the rubber seal...and everytime i push it back in for some reason when i accelerate in the low rpm's my car seems to shake/wobble back and forth but goes away in the higher rpm's...then a few days later my axle pops out again...idk why...and when i am pounding my car from second to third my trans grinds before going into third...but when driving regular it doesn't grind at all. and today when i was driving on the freeway it popped out of 5th gear twice out of no where...but i was able to put it in gear after though...idk whats the problem...someone help me out...
Old Aug 7, 2008 | 07:11 AM
neardon's Avatar
I'm a Jackass
Default Re: tranny problem (dc2[HI])
If the axel is leaking and popping out, you probably need a new one.
The transmisson is grinding and popping out of gear because you beat on it so much and its nearing its grave.
Old Aug 7, 2008 | 09:22 AM
89Turbo_Angel's Avatar
Default Re: tranny problem (neardon)
Try using Syncromesh tranny fluid to fix your grinding. It got rid of my 3rd gear griding completely.
Old Aug 7, 2008 | 10:53 AM
neardon's Avatar
I'm a Jackass
Default Re: tranny problem (89Turbo_Angel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89Turbo_Angel &raquo;</TD></TR><TR><TD CLASS="quote">Try using Syncromesh tranny fluid to fix your grinding. It got rid of my 3rd gear griding completely.</TD></TR></TABLE>
They dont make the good GM Syncromesh anymore I guess its just the generic "syncromesh"
Old Aug 7, 2008 | 11:03 AM
From what I heard, Pennzoil Synchromesh is the same as GM Synchromesh.
jchanth
12
Dec 17, 2008 03:52 PM
tcontesh
Apr 11, 2006 11:53 AM
Novtecdohc
Dec 15, 2005 09:09 PM
sleepin91teg
Oct 23, 2004 11:01 AM
tyflip2
Nov 10, 2003 09:52 PM
