brake light problem
Old Aug 5, 2008 | 03:24 PM
BeRightBack's Avatar
Default brake light problem
so today I was installing my type r spoiler on my 96ls, and now my brake lights don't work. I have the type r with the led light in the spoiler. so I decided that I would remove the factory 3rd brake light and wire up the new one. Now my brake lights don't work. I checked all of the fuses and can't find one that just says brake lights. The one's in the car, under the dash, are not for the brake lights (or maybe I can't find it), and the one's in the engine, say ABS, and when I check the fuses none of them are blown, maybe I'm just missing it. So my question is what do you guys think. I need help asap. Maybe I wired the spoiler wrong. I have black (spoiler wire) to black (trunk wire) and red (spoiler) to green (trunk).
someone help! PLEASE
Old Aug 5, 2008 | 03:54 PM
Default Re: brake light problem (BeRightBack)
alright I found the fuse, popped one, but however, the brake lights still don't work
Old Aug 6, 2008 | 07:21 AM
LSracing94's Avatar
its under then hood i believe it says HORN and STOP.
if that fuse is okay the next thing to look at would be your brake light switch
it is located under the dash on the arm of the brake pedal, it looks like a little toggle switch that pushed in and out. sometimes the rubber on them tends to get old and causes it to stay stuck closed.
Old Aug 6, 2008 | 10:15 AM
TEGadactyl's Avatar
Ya, thats a dangerous situation, if none of that works try to undo everything you did previously and put it back the way it was, see if they come back!
Old Aug 7, 2008 | 06:09 PM
Kmlnd24's Avatar
it could be a bad ground somewhere. i would check those because i had a problem with my brake light that it wouldnt work and i had a bad ground and that fixed it.
90AccordTx
Aug 8, 2005 04:24 AM
oo3
Jun 13, 2005 02:50 AM
Ragged91ZC
11
Mar 12, 2004 01:01 PM
LeonZ
Jun 21, 2003 04:17 PM
