ABS Codes
Old Feb 21, 2016 | 08:16 AM
ajcollins's Avatar
Default ABS Codes
Hey guys, I recently had my brake and ABS light come on in my 95' integra GSR. I have pulled the code and it gave me a 2 1 which as I read I believe is a parking brake code. Just wondering if anyone has run into this and what they did to fix it because I don't really know where to start. Thanks
Old Mar 27, 2016 | 09:43 AM
trm4life's Avatar
Default Re: ABS Codes
Well, just to let you know, according to my manual, the most common reason for an abs failure is dirty or worn sensors. They are simply magnets. Typically when your brake light comes on, the fluid is low. Some cars will actually throw the light for worn pads. Check for leaks, check fluid levels in both resiviors. Also you may need to clean and grease your slider bolts and replace the rubber boots. Very common issue for these cars.
f22suzuka
Apr 21, 2004 10:15 AM
gstintegra92
Aug 7, 2003 08:24 PM
AndyD
Jul 13, 2003 08:10 AM
social_control
May 23, 2003 06:27 AM
