h2b in a Da9
Old Apr 11, 2016 | 03:20 PM
ej_jake's Avatar
Default h2b in a Da9
hey guys I'm doing an h2b swap into my Da9. what mounts would be best for the swap? H2B mounts or Innovative B mounts? I've read where id need to get Innovative or Hasport B series mounts and I've also heard that id need h2b mounts for it. just need a bit of insight on it. everything helps. thanks.
Old Apr 13, 2016 | 08:46 AM
Hasport's Avatar
Default Re: h2b in a Da9
when you do an h2b swap you use the corresponding b-series mounts to fit the chassis of the car
Old Apr 24, 2016 | 09:27 PM
ej_jake's Avatar
Thank you very much. I heard you also have to grind down the block where the axle meets the half shaft. Is there anyway i can get a picture of where to grind? Or can i put the axle up to the halfshaft and just grind down that circular portion where the axle sits? How much should i grind?
Old Apr 25, 2016 | 08:54 AM
Hasport's Avatar
that is a question more in line to ask the people who make the H2B kits
Old Apr 27, 2016 | 12:22 PM
ej_jake's Avatar
Alright thanks!
Mfoehrkolb
Sep 21, 2012 09:22 PM
that1s10
Nov 16, 2008 08:06 AM
96hondab16a
14
Apr 11, 2006 05:24 AM
Jdm BB6
Mar 11, 2006 09:27 AM
Jared
May 27, 2002 07:42 AM
