Engine mount verification
Old Feb 14, 2016 | 10:05 PM
96GS-R's Avatar
Default Engine mount verification
Hey everyone it's time to replace all of my motor mounts but I need some verification before I place the order. I thank you in advance.
I've done a lot of research and was originally going to order the Hasport kit but due to the vibrations and this being a daily I have decided stick with OEM due to comfort.
I'm still a little confused about the correct ones to order. Hasport is a 3 mount kit but from what I've read, Acura uses 5 mounts total.
From my research/understanding the Type-R mounts are physically exactly the same, just slightly stiffer than the GS-R mounts and actually cheaper. Win/win in my book (Can anyone confirm?)
I've done my research but I'd appreciate if someone with more experience can confirm as it is an expensive order.
1. 50805-SR3-010 Rubber, Trans Mounting (MT) $97.58
2. 50801-ST7-Z00 Insulator, RR. Engine Mounting rubber (MT) $70.16
3. 50820-ST7-003 Rubber Assy., Engine Side Mounting (HYD) $196.40
4. 50841-ST7-Z00 Rubber, R. FR. Stopper Insulator (MT) $48.02
5. 50842-ST7-Z00 Rubber, L. FR. Stopper Insulator (MT) $48.02
Old Feb 14, 2016 | 11:30 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Engine mount verification
Yea theres three main engine mounts and 2 torque mounts located under the chasis, those usually go bad first and cause vibration and shifting issues. Just jack the front up and look under and check those two mounts, If there ripped most likely you can always use the energy suspeension torque mount insert its $25 on ebay.
Not sure on the main engine mounts but im willing to bet the ITR mounts are diffrent, But they will fit and will be perfectly fine.
Old Feb 15, 2016 | 12:23 PM
TOO MUCH TORQUE's Avatar
I put the ITR driverside torque mount in my integra LS. I did not notice any difference other than slightly more cabin vibration. I mean very slight.
Old Feb 15, 2016 | 11:26 PM
96GS-R's Avatar
Thanks guys. Appreciate it. Can you confirm those are the correct 5 to order?
Mutiny1
Feb 14, 2011 05:43 PM
Turbo-charged
Mar 11, 2008 04:24 PM
dso
Dec 2, 2004 05:15 PM
Clabbe
Jul 15, 2004 06:43 PM
solman74
Sep 21, 2003 11:52 AM
