What turbo you running?
Re: What turbo you running? (97CivicFerio)
a T3 60 trim .63exhaust running 10psi 1st gear 5psi 2nd gear 11psi 3rd gear fuggup boost controler
soon 10psi every gear and 15psi for track
Re: What turbo you running? (SiRkid)
straight T4E ball bearing .58 A/R and divided "hotside" (I think it's called the tang).
I run 8lbs 1st 16lbs 2nd and max 3rd and 4th(If I ever get that high ).
Re: What turbo you running? (liam821)
HKS AR.50 TO4E 42t/T3 stage III AR.63 @ .55~.7 bar on the car and an HKS T300S (AR.70 60-1/T3 Stage III AR.63) waiting for the 84.5mm bore block to be finished.
