steam cleaning engine
Old Jan 14, 2002 | 11:08 AM
ezark's Avatar
Default steam cleaning engine
anything extra you have to watch out for besides the dist. cap with a turbo setup? i plan on taking it to a car wash that does this. im not sure if they bagged off the necessary stuff last time i took it w/o the turbo setup, but they did a damn good job.
Old Jan 14, 2002 | 12:19 PM
93LSivic's Avatar
Default Re: steam cleaning engine (krazE)
Probably not a good thing to do when the motor is hot. Ever put cold water in a hot glass? Craaacckk!! What you should do is just buy some engine-brite or gunk and do it in your driveway with the engine cold. That stuff will work better than steam cleaning anyways, it has detergents that clean off the oils and other ****. Just get like a brass bristle brush and scrub the stubborn staines after you put the cleaner on. Then just spray off, and, viola--clean engine!
Oh yeah, look out for the intake, distributor, and basically any kinds of wiring harnesses and connectors (shock towers) if possible.
Good luck!
Old Jan 14, 2002 | 03:50 PM
FuzzyGreen's Avatar
Don't use Gunk unless you feel like having your car smelling like crap for a month or two. Use the Castrol Super Clean stuff. It smells better and works just(or almost) as good. Also it is more environmently friendly.
Old Jan 14, 2002 | 03:53 PM
dustin's Avatar
Default Re: steam cleaning engine (FuzzyGreenCarpets)
Use simple green.
Old Jan 14, 2002 | 03:58 PM
Aahj's Avatar
Default Re: steam cleaning engine (dustin)
Use simple green.
hells yea,
or even PURPLE POWER!
Old Jan 14, 2002 | 05:52 PM
lazyvietboi's Avatar
doesn't that stuff eat up rubber?
[Modified by lazyvietboi, 6:53 PM 1/14/2002]
Old Jan 14, 2002 | 06:24 PM
SIK IN DA HED's Avatar
New User
Default Re: steam cleaning engine (lazyvietboi)
wont steam cleaning a turbo'd engine be too risky? could get water all over the teflon tape or loosen up a seal or something. get water between the cracks and cause rust to form. i dunno...
Old Jan 14, 2002 | 06:32 PM
Smashback's Avatar
Default Re: steam cleaning engine (dlplayboy)
That's my concern ... the turbine housing and exhaust manifold would be very prone to rusting. When my oil return broke and splattered oil all under my car I wanted to do this, but I think I'm going to jack it up and hose it down with degreaser instead.
Old Jan 15, 2002 | 10:28 AM
ezark's Avatar
hMm, the risk may not be worth it. looks like i will be doing some cleaning myself, and keepin' off the turbo parts.
anyhow, thanks for the eyes open
[Modified by krazE, 7:30 PM 1/15/2002]
-=ZAK=-
Jan 9, 2009 08:08 PM
TheNasty0ne
Aug 26, 2005 04:27 PM
RUBZERK
Oct 22, 2003 05:59 PM
95hybridcivic
Jul 10, 2002 06:34 PM
SlowB16
Feb 1, 2002 06:39 PM
