How tough to pull off 13.0's??
Old Jan 15, 2002 | 06:00 AM
1996GsrVtec's Avatar
Default How tough to pull off 13.0's??
How much boost on a Gsr with forged internals to run 13 flats?
Old Jan 15, 2002 | 06:01 AM
newsense's Avatar
New User
Default Re: How tough to pull off 13.0's?? (1996GsrVtec)
depends on: compression ratios, slick size, weight of car
on average i think a gsr at stock compression could run a 13.0 at 5-6psi on 22in slicks
[Modified by newsense, 10:02 AM 1/15/2002]
Old Jan 15, 2002 | 06:28 AM
VTC_CiViC's Avatar
Default Re: How tough to pull off 13.0's?? (newsense)
At only 5-6psi of boost!?
Old Jan 15, 2002 | 06:40 AM
Seraph0's Avatar
Default Re: How tough to pull off 13.0's?? (VTC_CiViC)
I ran a 13.3 at 108MPH at 6-7psi on 22" slicks. Plenty of power, not enough driver.. ha.
Old Jan 15, 2002 | 06:44 AM
VTC_CiViC's Avatar
Default Re: How tough to pull off 13.0's?? (MarkC)
Whoaaa.. I need slicks!!
Old Jan 15, 2002 | 08:18 AM
newsense's Avatar
New User
the trap speed is definitely there for you to run 12's.... what are your 60 ft times like?
Old Jan 15, 2002 | 09:40 AM
Seraph0's Avatar
They were like 2.1 I am thinking. I am very gentle on the launch. I haven't broken anything in 2.5 years of being turbo!
Well I take that back. I broke one axle. I was coming out of a gas station and did a hard 1-2 shift with the steering wheel still not totally straight and broke one. Not catastrophic tho. Limped home and changed it.
Old Jan 15, 2002 | 09:59 AM
VaporTrail's Avatar
New User
how did you limp home on a broken axle? Even if you had a diff, that would put extreme amounts of load on the drivetrain. Scary stuff
Old Jan 15, 2002 | 10:05 AM
newsense's Avatar
New User
i hear ya on that... but i got to say... the car will take alot more abuse than you think.... 22in slicks should net you in the 1.8-1.9 range on your 60fts... I was pretty skecthed on launching at 5500 too at first but once i figured its better to spin a little that have them bite real hard and wheel hop, it was all good... ive been turbo for 2.5 years as well, and to this date have never broke an axle (knock on wood)..... ha ha ha ive blown a motor tho
Old Jan 15, 2002 | 12:30 PM
Seraph0's Avatar
Default Re: How tough to pull off 13.0's?? (VaporTrail)
I think I just broke something in outer CV joint. Wasn't too bad. I only had to drive about 2 blocks from the gas station to my place.
Old Jan 15, 2002 | 12:32 PM
VTC_CiViC's Avatar
While we're talking axels here, how much power do you think Honda axels are good for? I know my D16 axels are a bit skinnier than B-series but I wanna have a rough guesstamate as to how much these things can hold.
BTW I'm going w/ driveshaft shop axels soon so I won't have to rely on these
Old Jan 15, 2002 | 12:36 PM
Seraph0's Avatar
I don't think it depends as much on how MUCH power, bit more on how you LAY DOWN the power.
Make a mistake like I did punching it out of a gas station in first with the steering wheel still turned a little as you shift hard to 2nd lighting them up the whole way and your axles will be a little unhappy.
Old Jan 15, 2002 | 01:35 PM
FBP Ex-T's Avatar
that is my goal....to run a13.0 on my sohc....w/stock internal's full interior....i hope i can do it.....oh well....give me a lil while lol i havnt even put the thing on yet.....anyone wanna loan me some money lol
u can surely run a 13 flat.....w/stock internals boostingl ike 9 psi on street tires for a gsr poc
Old Jan 16, 2002 | 03:36 AM
Mista Bone's Avatar
D Tranny Guru
go0d to 200 hp so far without issues. By spring I'll be hitting 225-230 hp on spray. 12.99 or spit a rod, ZEX baby!
Old Jan 16, 2002 | 08:02 AM
rtype11's Avatar
its all relative, alot of transplanted motor will break axles easier because of the geometry change when banging gears, most people do not use the two torque mounts that b series have in Civics or whatever this adds to higher angular load and balnce shifts in the axles causing them to go out of round during acceleration leading to higher stress loads on cv/axle. dumping the clutch with min 320lbs of torque should kill stockers every time.
racerjohn
Oct 29, 2006 11:05 PM
BoOsTiN Dc2
Apr 3, 2006 03:54 AM
b20turbojason
Nov 10, 2003 09:53 PM
HotRodTeg
Nov 14, 2002 06:20 PM
pagong
May 9, 2002 11:36 PM
