b20 turbo
Old Jan 13, 2002 | 04:09 PM
b16sipsssh's Avatar
New User
Default b20 turbo
Im putting a b20 into my 00 si and running the Drag III kit with ls tranny and upgraded ball bearing and wastegate. Just wondering what my times in the 1/4 mile should be around boosting 10psi????? Also wondering if theres a better tranny for the motor then ls??? stock b20, no vtec!!
Old Jan 13, 2002 | 04:35 PM
b18bturbo's Avatar
Default Re: b20 turbo (b16sipsssh)
you should running low 14s to high 13s if you can get traction.
Old Jan 13, 2002 | 04:46 PM
jinxproof99's Avatar
New User
i'd run a gsr tranny. the b16/type r might be alittle too much for the torque your gonna make. i'd get whichever one you can find quicker/cheaper.......but lose the ls.
Old Jan 13, 2002 | 05:06 PM
ekb18c's Avatar
Default Re: b20 turbo (b18bturbo)
You should be in the low to mid 13's with that setup, running slicks offcourse. IMO the ls trans is good for boost. With the longer gears, you will stay in boost for a longer period of time.
Old Jan 13, 2002 | 05:33 PM
bloobin's Avatar
Default Re: b20 turbo (ekb18c)
Keep the LS tranny, stay in boost as long as you can, cause thats where your power is!
Old Jan 13, 2002 | 09:19 PM
2080 b20's Avatar
so then at about 14 psi it could be possible to hit 12's??
Old Jan 14, 2002 | 07:13 AM
TurboITR's Avatar
Default Re: b20 turbo (2080 b20)
very easily
Old Jan 14, 2002 | 10:19 AM
iceburgslim's Avatar
Keep the LS tranny, the other trannys gearing are too short because the motors they go with have very narrow powerbands...your B20 however, has torque and boost!!!!!!!! Hope that helps!
sohc-ek4
Jun 8, 2009 12:14 PM
callmecannon
Apr 27, 2008 07:03 PM
JDMJAYDC2
Apr 9, 2007 07:48 PM
phatboy
12
Apr 4, 2004 07:57 AM
kholmes
Jan 25, 2004 04:37 PM
