Compression Test on my 97 GSR
Old Jan 15, 2002 | 04:02 PM
busman's Avatar
Default Compression Test on my 97 GSR
I had my friend who's an Acura Mechanic do a compression test on my car. The numbers came up....200-200-200-180. The car has got 60,000 miles on it. He says it's fine but I'm a little skeptical about it. Anyone have any input???
1997 Integra GSR
AEM CAI
AEM Fuel Press. Reg.
AEM Fuel Rail
B&M Fuel Press. Gauge
DC 4-1 Header
Tanabe Racing Med.
ClutchMasters Stage3
ClutchMasters Lightened Flywheel
Venom 400
Tokico Struts
Eibach Springs
Lower Sway Bars front/back
Old Jan 15, 2002 | 04:04 PM
D-SPEED's Avatar
Default Re: Compression Test on my 97 GSR (busman)
im pretty sure that is OK, just on the lower side of what most people with healthy motors get. I got 230 230 235 230 .. which was kinda high ?
Old Jan 15, 2002 | 04:29 PM
Anthony K's Avatar
New User
Default Re: Compression Test on my 97 GSR (D-SPEED)
210 across the board for me. Maybe try it again, or use a different compression tester?
Old Jan 15, 2002 | 04:31 PM
dustin's Avatar
Default Re: Compression Test on my 97 GSR (Anthony K)
I get 210 sometimes, 220 somtimes, I have even gotten 230psi across the board. Consistency between cylinders is what you are looking for.
Dustin
Old Jan 15, 2002 | 04:45 PM
Anthony K's Avatar
New User
Default Re: Compression Test on my 97 GSR (dustin)
Your car is fine Busman.
Old Jan 15, 2002 | 05:46 PM
sa21199's Avatar
if your compresssion is really low how can you fix it? lets say he got 180 in all cylinders would it be time for him to buy a new headgasket or new pistons?
Old Jan 15, 2002 | 05:50 PM
JCushing's Avatar
Default Re: Compression Test on my 97 GSR (sa21199)
prolly rings. a headgasket will make the comp drop around the pistons near the leak. if you have even #'s and the engine feels decent then your prolly ok
course if your replacing rings youd be an idiot not to do the head gasket too.
[Modified by JCushing, 9:51 PM 1/15/2002]
Old Jan 15, 2002 | 06:08 PM
TurboSedan's Avatar
New User
Default Re: Compression Test on my 97 GSR (JCushing)
Those numbers are alright man, I wouldn't worry. If one of the cyclinders was about 50psi lower than the others then I would worry.
drave
Nov 21, 2010 01:55 PM
Andres-eh2
Sep 15, 2003 02:31 PM
Petah
Aug 19, 2003 11:37 PM
cjDC2
May 23, 2003 01:11 PM
speedymon
Jan 10, 2003 08:02 AM
