DSM injectors in a GSR manifold..
Better than steak
I just got the DSM 450cc injectors in and they fit pretty good, but my questions is what clip do I uses, GM? http://www.turbomafia.com/Arturbo/injectors.jpg
Also, I didnt have either dsm or honda o-rings but which one are cheaper and work? Im king cheapo remember?
sgT, some help...
art
sgT, some help...
art
Re: DSM injectors in a GSR manifold.. (Arturbo)
Art, the obd1 civic clips should work, you might have to cut the notch out in the clip depending on what yr injectors you have, but they should work. Also are you going to be using this with the hondata? If not you'll need a resistor box for the 450cc. How did the injector seals fit?
Corr Performance Pilot
Chingado.... go to http://www.c-speedracing.com My boy's got what you're looking for. If not.... ask him.
Hasta Los Huevos!!!
Hasta Los Huevos!!!
Better than steak
Re: DSM injectors in a GSR manifold.. (MouhadIb)
Hasta Los Huevos!!!
Hasta Los Huevos!!!
RC/GM clips will work - thats what i am using on my 755cc dsms
[Modified by TurboITR, 2:16 AM 1/15/2002]
GM clips fit fine.
OBD1 clips fit with a little mod apparently.
O-ring, honda or dsm, i dono which is cheaper. I use honda o-rings.
You will need to use a resistor box whether you are using a hondata or not.
Re: DSM injectors in a GSR manifold.. (sgT)
Correct... OBDI honda clips will work. You will need to modify the clip slightly. Regardless of what you use, you will need a resistor box.
Arturbo: you emailed me? I never received anything from you.
So the 2nd Generation DSM 440cc Injectors will work with the OBD I harnesses, correct?
Art:
You did have to run ballast resistors due to the lower impedence, correct?
Art:
Hasta Los Huevos!!!
I already did and got no answer.. And since when did you turn gay and find a boyfriend?
Hasta Los Huevos!!!
Better than steak
Gracias a Dios que somos hermanos...
Thanks everyone for the replies everyone.
G3-TEG I didnot email, but replied to your thread in the ITR forum but thanks for all clearing all my questions...
art
art
