quick question:Are Talon injectors the same as...
Old Jan 18, 2002 | 06:44 AM
RAWB's Avatar
Default quick question:Are Talon injectors the same as...
any other DSM ones? I found a guy sellin some off of his Turbo/Talon, and I know this car was basically the same as the 1st gen DSM's. Also, since my engine is a 1st Gen B16, these should be plug and play. Also, the guy couldn't tell for sure if they were Peak/hold(which I need) so since he's local, I guess if I take a resistance reading across the injector I should be able to tell for sure, right(3-5 ohms)? Thanks
[Modified by integracon, 4:02 PM 1/18/2002]
Old Jan 18, 2002 | 06:47 AM
Flamenco-T's Avatar
Default Re: quick question:Are Talon injectors the same as... (integracon)
should be, the turbo talon and eclipse as well as laser are mitsu engine,.,..
the non turbo of all the three are chrysler engine
Old Jan 18, 2002 | 07:46 AM
VTC_CiViC's Avatar
Same car, P&H injectors.. 550 I belive
Old Jan 18, 2002 | 07:53 AM
RAWB's Avatar
Default Re: quick question:Are Talon injectors the same as... (VTC_CiViC)
450's, right?
Old Jan 18, 2002 | 07:59 AM
SiR Kid's Avatar
New User
Anyone have the 550's that they could measure the resistance on so I might get a clue on wether I need my resistor box reinstalled or not?
PLEASE It'd take like 30 seconds! I just need to know what OHM level you guys are seeing so I can compare to mine!
[Modified by SiR Kid, 11:16 AM 1/18/2002]
Arturbo's Avatar
Better than steak
25 Year Member
450
Old Jan 18, 2002 | 10:51 AM
93LSivic's Avatar
Actually the automatic turbo DSM's are 350cc's. Not sure on peak and hold or saturated between the 2 generations but I think they would follow as the 5 speed injectors.
Old Jan 18, 2002 | 11:30 AM
boomslang's Avatar
Default Re: quick question:Are Talon injectors the same as... (SiR Kid)
It's supposed to be 2-3 ohms for 450cc dsm injectors. Mine are all around 2.7 ohms.
Old Jan 18, 2002 | 05:13 PM
SiR Kid's Avatar
New User
Default Re: quick question:Are Talon injectors the same as... (Inlinefour)
THANK YOU!!!
Old Jan 30, 2002 | 06:35 PM
16g-95gsx's Avatar
Yep everyone here is right, aside from that 550 guy, heh
Old Jan 31, 2002 | 05:54 AM
Dublocivic's Avatar
Default Re: quick question:Are Talon injectors the same as... (16g-95gsx)
Are they 2g or 1g injectors? the 1g's are 3 something. Not 450cc.
Dsm 450cc are peak/hold... they are comparable to RC's just with a different spray pattern.
Old Jan 31, 2002 | 06:21 AM
dbman96's Avatar
New User
Default Re: quick question:Are Talon injectors the same as... (Dublocivic)
1G TURBO automatic are 350 - manual are 450.
Old Jan 31, 2002 | 07:17 AM
Dublocivic's Avatar
Default Re: quick question:Are Talon injectors the same as... (dbman96)
Thanks for the clarification.
ceemarun
Aug 7, 2015 05:21 PM
spotscivic
Nov 23, 2007 08:20 PM
spankaveli
Mar 8, 2003 09:05 AM
lildrgn2.0
Feb 20, 2003 11:48 AM
digitalhav0c
Jul 31, 2002 12:43 PM
