Zex Nitrous Kit Questions...
Old Jan 16, 2002 | 11:14 AM
DaNish's Avatar
Default Zex Nitrous Kit Questions...
I'm getting a Zex Kit in a couple of days and just have a few questions about it.
I've heard some people say you need to warm the bottle before u can spray...is that right, does the bottle have to be around 98 degrees to spray? If I were to spray and it was colder, what would happen...do you suggest buying a bottle heater, or what?
Lastly, I was first told to run a 65 shot that I just needed to retard the timing on my cam gear 3 degrees...now I'm being told that I need to adjust the ignition timing...which one is correct, or do I have to do both?
Old Jan 16, 2002 | 11:20 AM
DaNish's Avatar
Default Re: Zex Nitrous Kit Questions... (X DaNish X)
ttt
Old Jan 16, 2002 | 11:34 AM
newsense's Avatar
New User
The bottle will have its best pressure at 98 degrees. It does not have to be that temperature to be used, you will just have better results if it is.
Retard ignition timing, a few degrees should be fine.
[Modified by newsense, 3:35 PM 1/16/2002]
Old Jan 16, 2002 | 11:39 AM
DaNish's Avatar
Default Re: Zex Nitrous Kit Questions... (newsense)
Ok, so I don't need to retard the cam gear 3 degrees, correct??
How would I go about retarding the ignition timing a couple degrees?
Old Jan 16, 2002 | 11:48 AM
newsense's Avatar
New User
i would leave the cam gears alone... retard the ignition timing using a timing light
here are some instructions in case youve never done it:
http://www.c-speedracing.com/howto/timing/timing.html
Old Jan 16, 2002 | 01:37 PM
delacampos's Avatar
man...i'd buy a msd digital 6 asap. riding with your timing retarded a few degrees when not spraying is gonna make your car lag and run like ****.
[Modified by delacampos, 10:38 PM 1/16/2002]
Old Jan 17, 2002 | 10:08 AM
DaNish's Avatar
To adjust the timing do I have to disable the V-Tec by putting some sort of jump wire to the computer?
Old Jan 18, 2002 | 04:59 AM
Mista Bone's Avatar
D Tranny Guru
no, just make sure engine is fully warmed and idle below 875-900 rpm.
Old Jan 18, 2002 | 05:03 AM
newsense's Avatar
New User
Default Re: Zex Nitrous Kit Questions... (Mista Bone)
also make sure your fan is not running...
Old Jan 18, 2002 | 05:51 AM
DaNish's Avatar
Does anyone have a complete explanation of how to change the timing? Or maybe a site that tells you how...
Old Jan 18, 2002 | 06:00 AM
PM-Performance's Avatar
dont even bother changing the timing with 65 shot . if you do it on the dist , you will lose when not spraying
either get a dig 6 or dont even do it . . . your not spraying enough to have to reatard it . .
and the bottle warmer will be your best mod you can get with nitrous. i am living proof.
Old Jan 18, 2002 | 06:10 AM
newsense's Avatar
New User
see my above post..... ^ i put a link there...
kahwhy
Feb 17, 2008 11:30 AM
Sherm
Oct 11, 2003 02:56 PM
1.8EG-T
May 20, 2003 12:09 PM
joey1320
Feb 7, 2003 07:31 AM
See Are X
Nov 6, 2002 07:54 PM
