if you have a drag III for sohc and swap to B series, can u use the turbo by changing the manifold o
New User
can you just change the drag gen III turbo kit for a sohc civic 92-00's manifold and still use the turbo if you swap a B18c1 or any b series for that fact?
Re: if you have a drag III for sohc and swap to B series, can u use the turbo by changing the manifo
You can but I think all the sohc kits come with t04b compressors so you might want to swap the turbo out someday to match the new motor. But it will all bolt up w/ a new bseries manifold.
Dustin
Dustin
the B16 uses the same turbo as the SOHC kits....I just did this exact same thing...you will need a new manifold, and a new down pipe.
vboy714
05-17-2006 04:49 PM
1320DRAGWORKX
07-26-2005 07:15 PM
