car doesnt boost anymore
Old Jan 12, 2002 | 05:06 PM
FusionITR's Avatar
Default car doesnt boost anymore
this is on my eclipse, not my R,
i just got my car back from the alarm shop, they said they had to take some stuff out the engine and put it back on to get the 2 sirens in. Anyway, they hooked something up wrong because my car doesnt boost now, It boost gauge goes up from vacuum to about 1 or 2 psi then then it stop boosting and it sounds like a big BOV (but not quite a BOV sound), and the car stops accelerating (kinda like pegging the rev limiter). Anyone know what it could be?
Old Jan 12, 2002 | 05:19 PM
boost killz's Avatar
New User
Default Re: car doesnt boost anymore (FusionITR)
No offense but why the **** did they touch anything in the engine without letting you know first...... Anyhow why don't you ask them what they had to move? And just be sure to check turbo piping but I till can't see where an alarm install would interfere with anything having to do with the turbo besides the oil supply line and there is no reason they have to touch that. Good luck man and again definitely ask those guys who did the install what had to be removed and that should isolate your area of the problem.
Nick
[Modified by boost killz, 6:21 PM 1/12/2002]
Old Jan 12, 2002 | 05:24 PM
FusionITR's Avatar
Default Re: car doesnt boost anymore (boost killz)
i dont know why they moved stuff in the engine without asking me first, but no use thinking about that because they already did, but they told me they had to remove my air intake to fit the sirens in. Im thinking they put some tubbing on wrong on my intake (HKS). What do u think?
Old Jan 12, 2002 | 05:34 PM
New User
Fusion you referring to the intake filter leading to the turbo inlet??? or to the throttle body? I would check for any fitment issue on the charge pipe to the throttle body and tighten the coupler there a bit if it feels loose, because there shouldn't be any problem wih boost as far as your ar filter goes. Let me know man..Peace,
Nick
**** dude I am out of it,, I noticed the first sentece being eclipse not integra...DUDE check to make sure they conected the MAF plug back correctly! I can see the ca bogging and moving like **** if that isn't connecte correctly.. My bad dude hope that helps..
NIck
[Modified by boost killz, 6:36 PM 1/12/2002]
Old Jan 12, 2002 | 05:37 PM
FusionITR's Avatar
yeah, that
on the silinoid, theres a red labeled tube going to the intake and a blue labeled tube going somewhere else, could those tubes be cross or something? i dont know much about turbo so excuse me if i sound like i dont know what im talking about because i dont.
Old Jan 12, 2002 | 05:40 PM
New User
Fusion just remember the air filter and te rubber piping, not sure if you upgraded should lead to the turbo inlet, the other piping you are referrng to should be running to the IC in the fender. Hope this helps any man.. I know just a little bout dsm's ...bee a while since I seen there setup..
Nick
[Modified by boost killz, 6:43 PM 1/12/2002]
Old Jan 12, 2002 | 05:50 PM
FusionITR's Avatar
the car is bone stock besides the HKS super flow filter kit. So what exactly do i need to check for? what kinda problem does this sound like?
Old Jan 12, 2002 | 05:54 PM
HXMan's Avatar
There are soooo many vaccum lines on a stock turbo DSM engine. The shop could have easily connected a line wrong somewhere. Probably want to look closely at the ones that go to your BOV and wastgate.
Old Jan 12, 2002 | 05:57 PM
HXMan's Avatar
Default Re: car doesnt boost anymore (HXMan)
Oh yea...I can't remember exactly where, but on my friends TSI AWD there is a vaccum hose diagram on either the hood or front frame.
My friends car had vaccum lines hooked up wrong when he first bought it. We were messing with the lines, and comparing them to the diagram when we noticed a couple were reversed. His car was quick, but it was DAMN fast once we got them right!!
Old Jan 12, 2002 | 05:59 PM
FusionITR's Avatar
is there anywhere i can get a wiring diagram online? cause i dont think my car has any diagram on the hood or anything
Old Jan 12, 2002 | 06:24 PM
HXMan's Avatar
Did you look? My friends TSI is a 1994 also....your car should be pretty much exactly the same.
Old Jan 12, 2002 | 06:59 PM
FusionITR's Avatar
nevermind i just fixed it, moderators lock up/delete this post
PNK SLP
Feb 21, 2011 09:56 PM
samualjoseph
10
Oct 6, 2009 10:34 PM
90AcuraIntegra04
Feb 4, 2006 11:25 AM
buddha1320
Jul 20, 2005 09:03 AM
Obie
Sep 11, 2003 05:08 PM
