Can I hancle 310cc injectors?
1 Post
I think I need to upgrade my injectors... I've been told my problem running lean is due to the fact that my stock ones are going. I don't have any type of fuel management... jsut the stock integra gsr ecu and the fmu that came with my dragIII kit... would I be k with those injectors without any form of fuel management and the fmu I have now?
Re: Can I hancle 310cc injectors? (servion)
Yes you will be able to handle those injectors just fine, however you're problem may be with the fuel pump...depending on what disc fmu you are running get an intank or inline fuel pump.
1 Post
Re: Can I hancle 310cc injectors? (98hx99b18c)
so I'll idle fine and I won't run too rich all around? I have the dragIII kit, so I have an inline pump.... not sure about which fmu I have... If I had to guess I'd say 12:1..... but that could be wrong.... its just whatever fmu that comes with the dragIII kit.
Dont forget you'll wanna goto an 8:1 disc for the FMU when going to the 310's. You'll be fine with that. Now you crank the boost up a little more too!
1 Post
Re: Can I hancle 310cc injectors? (93LSivic)
I checked on mine.. and it's 10:1...... will that be too much? Can I change the disc instead of the whole fmu, and if so, where would I go about getting a disc? THanks
Re: Can I hancle 310cc injectors? (VTC_CiViC)
You might need and adjustable FPR and lower your base fuel pressure to get a good idle.
Damian
Damian
spoon95eg
12-19-2005 06:15 PM
B_1_8_hatch
09-11-2003 07:06 AM
