info:swap injectors 450 blue dsm 1gen for zcturbo?
i'm running tdo5h laser 1 gen in my zc dohc crx 90. booost around 9.5 psi in my stock injectors. I'm trying to put a injectors 450 from 1 gen dsm i already order the boost tight seal from zdyne for $50.00 today and i got a msd EFP in line. i have fuel control B&M. Do you think this set up would work for my turbo engine? And any idea what the best fuel preasure idle? thank's
Re: info:swap injectors 450 blue dsm 1gen for zcturbo? (turbozc2001)
Should work fine. I run a similar setup (D16 VTEC, TD04-15G turbo, RC 440's) and it works fine
Re: info:swap injectors 450 blue dsm 1gen for zcturbo? (VTC_CiViC)
no way, 450cc injectors with a B&M FP regulator?
I ran 1g DSM AUTO injectors that flow at 380cc's @20psi at idle and that was way to rich, fouls plugs all the time too.
You can buy the boost seals from Zdyne, or just make them yourself, get your stock seals and grind them out just a bit until they fit tight. I have used DSM injectors in my Motors for a few years..
Good luck
Jeff Frank
Good luck
Jeff Frank
Thank's for info again. But i got my zdyne seal today. I going to try anyway let see if work 450 DSM injectors to my zc turbo set up 9.5 psi. let you guys know today.
I had DSM 450s in my B16a for a few days just to test them out (I'll be using them in my turbo setup). With a Vafc and air/fuel meter, i was able to get them running fine after a hour of tuning.
It was between 25-40% leaned out across the board.
Just FYI
Just FYI
Re: info:swap injectors 450 blue dsm 1gen for zcturbo? (RioNinja)
what do you have the first one or second gen dsm injectors?
I got first gen dsm 450. I just put it today it turn out good idle 16psi fuel regulator top out 22psi fuel. little rich still and i'm still running 9.5psi boost on my zc dohc. Only one thing eat to much gas. i'm happy.
hondaluver12
06-25-2009 03:39 PM
rnbguy
05-12-2007 09:05 AM
