High temp paint
Old Jan 14, 2002 | 10:28 AM
dustin's Avatar
Default High temp paint
I need some paint to keep my new downpipe from rusting. I tried using that 1200 deg F paint when I painted my DP last... but that just flaked off the first 12" of the pipe near the turbo (I assume it got too hot hehe).
Any suggestions? (Other than getting stainless... let me know if you find stainless mandrel bends for cheap. And no, burnsstainless is not cheap. $90 for a 3" mandrel U bend no thanks)
Dustin
Old Jan 14, 2002 | 10:58 AM
cyan1de's Avatar
Default Re: High temp paint (dustin)
JetHot coating? tried that?
Old Jan 14, 2002 | 11:03 AM
dustin's Avatar
Default Re: High temp paint (cyan1de)
It's just a DP. I was sorta looking for something I could do myself...
Old Jan 14, 2002 | 11:12 AM
boomslang's Avatar
I painted my manifold and downpipe with some barbeque grill paint. I bought it at Lowes I think. It doesn't flake off.
Old Jan 14, 2002 | 11:16 AM
dustin's Avatar
Default Re: High temp paint (Inlinefour)
To lowes I go then...
Old Jan 14, 2002 | 11:21 AM
rtype11's Avatar
header warp it, with DEI 2"
Old Jan 14, 2002 | 12:35 PM
degradated's Avatar
New User
I have some 1500 degree farenheit paint. This is the highest temperature rating I've seen personally, but I have heard of paint that goes all the way up to 2200 farenheit. Not sure where you would buy it from.....but I'm sure that there are places on the internet that sell it.
Old Jan 14, 2002 | 02:02 PM
Farnsrocket's Avatar
Default Re: High temp paint (degradated)
Yep, I used 1500 degree paint on my manifold and it has been fine for 1000 miles. I got it at Jegs.
Old Jan 14, 2002 | 02:31 PM
dangerzone's Avatar
New User
http://www.hirschauto.com/acb/showde..._ID=11&CATID=1
1800 deg F
Old Jan 14, 2002 | 02:51 PM
Arturbo's Avatar
Better than steak
25 Year Member
thats the same exact stuff I used on mine....
art
Old Jan 14, 2002 | 03:22 PM
ArizonaTurbo's Avatar
They make this silver ceramic paint which works really well. I used it before I got my downpipe coated. I have it in my storage room, so I can find out what it is called and let you know.
Old Jan 14, 2002 | 11:35 PM
AbaZ's Avatar
http://www.por15.com/information.html
Great engine paint and manifold paint..
1400 degrees,
Old Jan 15, 2002 | 12:26 AM
lucas569's Avatar
Default Re: High temp paint (AbaZ)
will these high temp (the 1800 degree) really hold up on a turbo manifold?
if so im going to myself cause im having my manifold coated and its not cheap!
Old Jan 15, 2002 | 09:33 AM
BeeT's Avatar
New User
Hey, is that VC powder coated or did you just use a paint product from your link? Mine looked great when I started but after a while the white just looked like crap..
Old Jan 15, 2002 | 09:48 AM
rtype11's Avatar
Default Re: High temp paint (lucas569)
Sorry if it doesnt work, I want to show my motor also.
this was VHT Hi temp engine enamel, the same guys that make tire softening compound for racing, good up to 1800F, must clran surface before use that leaves no oil residue.
forget it I cant figure it out
[Modified by rtype11, 10:52 AM 1/15/2002]
[Modified by rtype11, 10:53 AM 1/15/2002]
GoLowDrew
Paint and Body
Jun 23, 2013 10:22 AM
BobGnarly
May 31, 2004 10:10 AM
The Alchemist...
Nov 16, 2003 11:04 AM
DanielLaruso
Sep 22, 2003 11:36 AM
Bklyn TSi
Dec 21, 2001 09:37 AM
