hks racing bov quetion
Old 01-12-2002, 03:34 PM
New User
Brian_92GSR's Avatar
Default hks racing bov quetion
I've got an hks racing bov - it has a vaccum source on the top port, and is open on the bottom port. Is the valve supposed to be open at idle? If I pull throttle cable just a little it shuts. Is this normal?
Old 01-12-2002, 03:36 PM
JM Performance's Avatar
Default Re: hks racing bov quetion (Brian_92GSR)
Think so.
Old 01-13-2002, 01:44 AM
turbopimp's Avatar
If this is the old HKS racing bov there is a bolt on top to adjust the spring tension. Turning this bolt clockwise will increase the tension and require more vaccuum to open it the valve, so if you want to close the valve at idle to prevent unfiltered air from entering the engine, crank the bolt down...
Old 01-14-2002, 02:49 PM
New User
Default Re: hks racing bov quetion (turbopimp)
Well, the f-max kit came with a smal k&n filter that fits right on to the blow-off valve, so I assume it goes on there for just that reason.
Eklsv-t
11-23-2007 06:00 AM
boostedK20a2
01-30-2006 07:42 PM
skrewdlude
07-11-2002 10:08 PM
TurbodCX
02-12-2002 11:57 AM
Quick Reply: hks racing bov quetion
