Will 60-1 turbo clear AC on teg?
like the question says....do I have to give up AC if I go 60-1 turbo on my gsr? I have t3/t4 now and it's tight as is...
Jeff-
Jeff-
Re: Will 60-1 turbo clear AC on teg? (dustin)
Let's see how happy you are about that in July... hehe
Prolly end up getting a "big ol lazy V8 car with cold A/C" like I did... hehe.
Re: Will 60-1 turbo clear AC on teg? (MarkC)
I drove the integra this entire last summer with no A/C I just never turned it on. It made the car bog for some reason when starting from rest.. ??
CRX does not have A/C either and I drove that through august in the heat
Dustin
Dustin
well, i prefer comfort over anything. But to get more power...t3/t4 is not going to get me anywhere...and 60-1 will hit my ac DOPE! Any other choices out there?
Jeff-
Jeff-
Re: Will 60-1 turbo clear AC on teg? (Corporal-Jeff)
You would need a new exh manifold with the 60-1. Why not do T3/T4 Stage V on the exhaust and a 60 trim on the intake? Stage V flows exhaust like a T4 as it has T4 internals and the 60 trim puffs a grip of air. This set up s/b good for 500 whp which is killer on the street. I made 440 with a Stage III and 54 trim. This should be the same physical dimensions as your current set-up and you can use your same manifold.
[Modified by earl, 6:45 PM 1/15/2002]
im pretty sure it will eliminate it.... the comp houing is bigger and it barely clears the block (i test fit one without the a/c bracket with a kooks manifold and it barely cleared... actually kinda touched the block as well)
now if photopoint was working i could show u pictures... motherers shut down though!
94 TuRbO dC2
03-07-2009 08:28 PM
mrbsponge
07-20-2004 05:16 PM
CheezeFrog
07-17-2003 09:19 AM
